2015 Jeep Patriot trans fluid
So I have a 2015 Jeep Patriot with a 6f24 6 speed automatic automatic 106,000 MI I'm wanting to drain and measure the fluid and replace with the same amount I took out my question is I just want to be sure that I am putting the right fluid back in it and I'm stuck between BG 312 atf or. Maxlife has anybody ever successfully used either one of these products and if so can you please recommend
I've never used it in a 6F24, but I would have more faith in the MaxLife than the BG. This is based on many transmission services across different makes and models using MaxLife.
