2014 Chevy 1500 0w20
Originally Posted By: Miller88
Isn't that what a pickup is supposed to be? Base model .. stripped down?
What do you do that voids Ford's warranty?
Obviously the people actually buying pickups disagree with you, as most are sold loaded. Some of the stuff is whacko even to me, but i don't want a stripper unless it's a work truck.
We use our vans as stationary power plants, taking power off a shaft driven from the front end of the engine. We also use a heat exchanger in the cooling system to heat water.
Go here to see what one looks like: http://butlersystem.com/butler-system-in-regular-and-extended-length-vans.html
I guess I've always been of the mindset that a truck is for work.
What I asked came off as snotty ... didn't mean it as such. Was just curious.
Ah, I'm guessing that requires extensive modifications that would void it?
No worries here, no offense at all. One of my trucks is for me, the others are all for work.
Our machinery is installed by a Factory Authorized Upfitter, which means we have a full warranty just like any other GM product these days.
Originally Posted By: hatt
A real pickup owner looking at serious towing isn't going to get the base engine.
The 4.3 engine if properly equipped will tow 7,000 pounds. More than probably 80% of truck owners will ever tow. If your towing more than that regularly, you should consider a heavy duty truck.
