Ironically garaging your car can be worse than parking it outside, salt doesn't do much corrosion if it's below freezing, but when its warmer (such as in a garage) it can get to work.
Look at the bright side. Now he can service the rear wiper motor from the outside.Could be worse. Here’s a Kia Sorento I saw yesterday.![]()
Out here we have, "Cactus Jack's" For real.I would put that on Fast Eddies used car lot........
VW's generally have an excellent bodyshell, from the rust-proofedness perspective. At least it seems to me to be the case...Its not good either, my 1999 VW Beetle only sees winter use for the last 8 years and still has no rust and its 22 years old.
Funny, i have a '97 Civic 2 door, and despite some breeches in the paintwork and minor rust at those very few locations the car seems to NOT want to rust at anything like the rates I've seen in many cars. It has to come down to the cleanliness of the steelmaking, the steel chemistry, I don't know. Mebe exactly what you say, above...I have seen several Honda's have rust issues over the years. It may be that the iron content of the sheet metal they use is higher than other comparable makes...
That'll buff out.I think with Honda it's more of a lack of quality of their steel. I remember back in the mid to late 80's, they had a recall on Accords that had major issues with the fenders rusting through in as little as 2 years on cars driven in the rust belt.
They ended up replacing many free of charge. I had a co worker at the time who owned one, and got 2 free fenders out of the deal. But it didn't matter. The thing was a bucket of rust after just 5 years. It would appear this problem is ongoing with them.
But don't German or northern European cars use (more?) galvanized steel on the lower body and resist rusting better?Its not good either, my 1999 VW Beetle only sees winter use for the last 8 years and still has no rust and its 22 years old.
Nope the will replace that whole rocker if he wants it fixed right.I have seen several Honda's have rust issues over the years. It may be that the iron content of the sheet metal they use is higher than other comparable makes. Another thing to consider for anyone who frequents touchless automatic car washes is that they use either high akaline or acidic presoaks as chemical action to dissolve and remove the solids prior to the rinse cycle. These high concentrations of either base or acid chemicals cannot be good for repeated use on automotive finishes and coatings. The mechanical action washes that use traditional mitters, and spinning pads use chemicals and soaps that are less harsh. Lastly most automatic washes recycle a percentage of their wash water. This also equates to many vehicles being resprayed with filtered waters that may have dissolved road salts in them thereby adding insult to injury.
As far as repair to your Dad's car. The repair needs to start by mechanically (via sanding) removing all the corrosion on the exterior. Then chemically treating the interior of the panel with some kind of corrosion or rust converter. After the perforated holes are welded shut on the exterior skin, then both the interior and exterior of the panel surfaces can be sealed and coated with proper primer and paint coatings.
Some shops or individual owners will then go the extra route by spraying the interior of the panels with some kind of wax or petroleum based coating like Fluid Film. I once worked for a fellow who grew up in Minneapolis. He would spray all of his cars through the panel drain holes with some kind of oil mixture so much so that it would be dripping out of said drain holes for days afterwards. His rust preventative measures did work very well as a result.
Good Luck with the repairs, and now you know the reason why rust is called "cancer" by many in the industry.
I live in the city and drive in Boston often.A lot of "Winter use" varies a lot in terms of rusting. If you live in the city, your vehicle is going to see a LOT more salt, along with salty water and slush, than if you live far out in the suburbs.
The inner city salts constantly in the Winter. I remember seeing literally piles of salt at intersections, where salt trucks sat at red lights with the spreader spinning.
In the more rural areas they were lucky to get plows to get through.
They do but others do too or so its claimed. The sheet metal and ruggedness of the VW and most other German cars (we wont talk about some GM Opel models) is far superior to anything used on Japanese cars.But don't German or northern European cars use (more?) galvanized steel on the lower body and resist rusting better?
