Russian video showing a rebuild of Cam Adjuster with hardened center plate.
https://www.youtube.com/watch?v=18_2gx2Z2R4
Google translate;
8 903 534 10 02
CALL
COUPLING CAMSHAFT INLET AND OUTLET Kit for Mercedes Motor 271 Turbo EVO
A 271 050 14 00
A 271 050 15 00
Timing camshaft clutch on an M271.8 evo 271.820 271.860 engine.
Moscow development, factory production in German equipment.
THIS IS NOT CHINA = NOT TURKEY = NOT YTM = NOT RUEL = NOT RESTORED ON THE KNEE == FACTORY QUALITY!
==================== ATTENTION! ========================
We fixed the 271th clutch in the likeness of the clutch on the 274th-278th motors that rarely fail and work on 200t.km — we used the same alloy and the same production technologies !!!!
All necessary tests have been carried out. The internal mechanism is modernized - the metal is reinforced to 60 units. and the surface is "cemented." In these couplings, the teeth do not wear out, in them the internal mechanism fails. Do not confuse with the compressor option! Therefore, there is no way to check this in used couplings.
EXCHANGE WARRANTY-360 days! "
Suitable for all 271 turbo engines 2007-2013 onwards
Resource from 90 to 200 thousand km, subject to timely maintenance !!!!!
For comparison:
The resource of the original ~ 45-90 thousand km
The resource of the original with a brewed mechanism less than 1000km.
Second-hand resource of the original ~ 1-2tys.km.
Resource of Chinese \ Taiwan \ Turkish analogues ~ 0.km
Each coupling is configured on a test bench.
Write.
There is WhatsApp, Viber.
We give a guarantee without a mileage limit - 12 months!
12 months exchange
(Attention! -New original numbers!)
A2710501400
A2710501500
(ATTENTION! -Old numbers are different!)
A2710503347
A2710503447
A2710502547
A2710502647
A2710501400
A2710501500
271 Turbo engines are suitable for Mercedes S, E, Coupe and other classes of different generations and years: since 2010!
The price is per unit.
Terms of delivery: only for exchange (first your old to us, or on bail).
SENDING TO REGIONS = Business Lines or SDEK
We work on weekends!
8 903 534 10 02
CALL-ask-ANSWER!
WE BUY OLD MERCEDES COUPLINGS!
