Ran PUP 5w30 for years and worked fine. Then ran Mobil 1 Euro FS 0w40 which seemed to quiet down the engine at high RPM when flooring it. Currently run Castrol Euro 5w40 as I currently have a stash of this due to a Walmart pricing error last year.
Any oil appears to be fine, though VQs seem to be a little harsher on oil and going to any Xw40 would be ideal. The engine itself is old and virtually bulletproof minus the gallery gasket issues.
Common issues to look out for those cars:
- Gallery Gasket - I think these were replaced with metal gaskets for 2012 Fall manufactured cars and onwards.
- Sunroof drain clog/leaks - the body control module is on the passenger side floor panel and if you have a leak, you may get electrical gremlins along with bad moldy smells.
- Rear diff bushing - these seem to go crack and leak oil (look for streaks on your diff housing) - OEM does not sell this piece separate from the rear subframe so you either shell out the big $$$ or you can replace it with aftermarket urethane bushing (i.e. Z1 motorsports, etc.) - I did the cheapskate method of lifting the car up and filling up the empty bushing with epoxy.
- Radiator and heater core hose and coolant bleeder port (near the heater core hose) leaks - will happen sooner or later due to degradation of the plastic and rubber.
