Originally Posted By: BigJohn
An interesting twist to this story. In my owners manual (2012 Ram Hemi 2500), it states that I should follow the oil recommendation that is printed on the oil cap of the engine.
Printed on the cap is.... 5w20
But in the manual for the 2500 Hemi, it specs 5w30
Today I poured out the Factory Fill (with 750 miles on the truck) and it was obviously a very thin, 20wt.
In its place, I poured in Pennzoil 5w30 conventional. I will run it for 3 months and about 4k miles and then I will permanently move to Pennzoil Platinum 5w30.
Haven't looked at the 2012 manual but it used to be under 14,000 GVWR used 5W20 and over 14,000 GVWR used 5W30 in the HD's with the HEMI( 2007 and on ).
Yeah, the Max Towing Rating for my truck is 10,550 lbs. If I had 4.10 gearing it would be 13,550 lbs.
The only way I can see to get over 14,000 lbs is to have a 4x2 truck and 4.10 gearing. So am I to assume that the only Hemi 2500 trucks that can use 5w30 are two-wheel drive with 4.10 gears.
Funny.......
Nope....I was mistaken....
The oil recommendation is based on the GCVW...and it is 17,000 for this truck.
Funny.......
