Hi,
I'm looking for input on the oil to use, the filter to use, and the suggestions related to the first change.
The suggested interval (including first change) in the manual is 3750 miles/3.75 months.
From the "What oil should I use" post:
1) 2011 Subaru STi Hatchback
2) Oil grade:
"ILSAC GF-4 or GF-5, which can be identified with the ILSAC Certification Mark (Starburst Mark) or API classification SN or SM with the words "ENERGY CONSERVING""
5W-30 is recommended.
From the graph (estimates, as the graph is not clear):
-30C or lower to 40C or higher, 5W-30, 5W-40
-10C to 40C or higher, 10W-30, 10W-40
Under severe conditions:
API classification SN (or SM):
SAE viscosity No.: 30, 40, 10W-50, 20W-40, 20W-50
3) I live in San Antonio, TX USA
4) I am (trying) to drive the car somewhere in the middle, but I will be driving the car hard in general, post break-in (1000 miles).
5) Daily drive is mostly city, from 0-45mph, about 5 miles to work and back, plus errands. Weekends will be mainly highway, 70mph being the general speed limit, for 30-200 miles. This is not counting track days, which will be track/driver limited speeds.
6) No known problems, it's brand new. Only 160 miles on it (not bad for 2 days of ownership, all city miles.)
I'm not too concerned with money, maintenance is inexpensive compared to repairs. I'd actually like to do oil analysis (suggestions here.. Blackstone?) on each change. I want the best for my engine. I'm looking for both summer and winter suggestions, bearing in mind the heat in TX. If the same oil is fine for both, that's wonderful, if I should switch at a certain average temperature, that's fine too.
Also, as mentioned, I'm looking for filter suggestions. On both oil/filter, I'm open to purchasing online, or locally.
Thank you,
David
2) Oil grade:
Thank you,
David
