2011 Cruze- 1 month review
Originally Posted By: dishdude
I am seeing everyone complain about how autos are shifting. I wonder if people just aren't used to 6 speeds, or if the automakers really need to work on their programming.
Most 6 speeds are fine, honestly. The problem with the programming in the Cruze auto is that
1. It tends to shift much higher under light acceleration than necessary, killing gas mileage (shifting in manual mode results in much higher city and combined numbers)
2.It doesn't always shift smoothly. It usually does, but it's inconsistent.
This could all be fixed with a reflash, and I'm actually anticipating one coming out in the near future, but i could be wrong.
If GM doesn't provide an updated reflash to fix the transmissions behavior, there are tuners out there that can do that. There is a program called HPTuners which is the software that was used on my Corvette and one of the things I had adjusted on the programming was the part throttle 3-4 shift, as I didn't like how it shifted far too early. You could easily do the opposite with this program, and have it set up so that the part throttle shifts happen sooner. I also was able to adjust the full throttle shift points (moved them to 6100 rpm instead of 5800) and speed up the shifting time as well so that it didn't lag so long on the shifts. I'm not sure if HPTuners supports the Cruze yet, but if not, eventually they will. The typical cost to get an expert tuner to work his magic on your car's programming is about $400, well worth it when you consider all the benefits it provides (it can also turn on the fans much sooner so the engine doesn't heat up as much in traffic, and it can set up the engine's fuel mapping and timing curve to run more efficiently for better MPG and better horsepower)
Nick, nice review. I think you may come to appreciate a higher shift point; I have in my cars. My Toyota Camry would often upshift as early as it could to preserve fuel economy, and both of my Hondas are opposite of that; they wait to shift until higher in the RPM band. Intuitively, you'd think its wasting fuel that way, but I don't think the difference is that much, and I appreciate having the engine's power if I want it.
One of the things that frustrated me most with the Camry was the transmission. And probably the shift programming and not the transmission itself. Quite frankly, it felt like a Chrysler 41TE. I owned two of those and the minivan at work has one also. They're normally smooth, but if you let off the throttle during a shift, or just before a shift, it'll clunk into the next higher gear. Toyota did come out with a flash for transmission shift programming, but I think all it did was reduce the sensitivity of the gas pedal in the first 25% of travel. Throttle take-up was smoother, but shifting really wasn't.
Otherwise, sounds like a nice car and I'm glad you're happy with it.
Thanks for the great review!! I should be getting my new 2012 Cruze 1LT within a week or so. Really looking forward to it!! Now the question is what brand of oil...I'm thinking PP or Ultra, 5w30. Tom
Quaker state ultimate durability seems to be a great choice its what I'm going to put in tomorrow.
Most likely Dexos rated oil as the FF, why ruin a perfectly good oil? Keep it in there till at least 5k miles. Save your money for something else.
All turbo's today are water-cooled as well so reliability is something I would not be concerned with. Even on hot shutdowns heat will siphon away from the turbo bearings via the water jacket.
Glad you enjoy it. I still think I may go back to a TDI even with all these choices...
Changed the oil today, QS UD 5w30, 4.5qts, and the new ACDelco filter. It was really easy to change the filter, and the oil would be easier but it's very low, so jacking it up is necessary. A oil extractor would make it so you don't even have to get under the car.
Took some pics of the engine bay while I did it. Lots of european parts on this engine. Lots of stuff from Germany, and Czech republic. Took a picture of just a few. Looks like they imported a lot of parts to the Flint Engine plant. They also really liked Bosch on this car.
Throttle Body motor and controller
Air intake hoses and manifold made by Mann-Hummel in germany
Bosch/ACDelco Alternator, Mexico
Electric Fan, Bosch, USA
Nother shot of the TB
Shift linkage
http://s266.photobucket.com/albums/ii279/rudolphna/?action=view&current=IMG_0738.jpg
Compressor, and the Belt and accessories. The two round metal things at the top are the VVT actuators at the end of the camshafts.
Front driver wheel assembly
Underneath
Truly a global car
This was today. I said 40.8 earlier, I was wrong. This was after a 70 mile highway driver, cruise set about 68mph, with A/C on. ~75f ambient temps. Not bad, not bad at all. This was running 89/Midgrade which seems to help so the timing doesn't retard as much as it does on regular.
Just have to watch the rim depth to clear the calipers. So some test-fitting would have to be done.
Reason I'm asking is that 205/70-15 snow tires are cheap and widely available. I also have a set that would need new wheels if I get a Cruze.
Nick, can you please verify your fuel economy on a long trip? I've heard reports that the average FE display is 10% optimistic.
So you were running it in manumatic to huh?
Impressive numbers, not surprised about needing 5w30 either. Most Turbo's would shear a 20 to quick.
Originally Posted By: css9450
Hmmm, I must have missed class when you bought this car. What happened to the Focus?
Nick missed his Cavalier and felt he was betraying GM for buying a Ford. He felt SO guilty, he got his entire family to trade in all their vehicles on new GM products
Well, that's pretty much how it went, right Nick?
hehehehheheheh
Anyway, he's happy now
hehehehheheheh
LMAO!!!!
More like he convinced them to trade in a beat-to-death Expy and a Focus he was totally not thrilled about driving. At least everybody's happy now.
hehehehheheheh
LMAO!!!!
You forgot the Mustang in there
And not in total agreement on the beat-to-death on the Expie. It had less miles on it than mine from what I recall, and was newer. And for sure was not driven as hard
However, I agree with you completely regarding him not being happy with the Focus. But that goes back with him being a GM guy at heart, which he agreed with the last time I said it to him
NickR,
I know I'm a car nut when I enjoy looking under the hood of a car more than the sheet metal!
Looking at your pics was entertaining, thank you. GM has come a LONG way. Glad to hear you are enjoying the Cruze.
hehehehheheheh
Sort of I guess. I did like the Focus, don't get me wrong. If my parents hadn't decided that they wanted to trade in their cars, I would have kept it.
hehehehheheheh
LMAO!!!!
Yeah I am more of a GM guy, don't really know why. Practicality was a big part of it.
Also, I do feel it's worth mentioning that the more miles I put on the car, the better the transmission gets. This shouldn't be news to anyone familiar with these learning transmissions, but it gets better, smoother, and more predictable every day.
