Originally Posted By: gregoron
My guess is that you need a higher HTHS and lower NOACK oil of the same grade first then think about going up a grade. If you do go up a grade, I'd go shorter intervals as your engine might break down that thicker oil faster. Have you been using OEM filters?
There is neither high-temperature nor high-shear at the valve guides, therefore the oil consumption through valve guides is controlled by the low-shear (kinematic) viscosity at around 100 C, not the HTHS viscosity.
However, if there is consumption past the rings, HTHS viscosity might perhaps be better correlated with that, as it's a high-temperature, high-shear environment like the bearings.
Lower NOACK, meaning low evaporation, will reduce the oil consumption a little but not if it's happening through the valve guides. However, unless you use a CJ-4 15W-40, which all have low NOACK but are still cheap because they are dino, low-NOACK oils are synthetic and expensive for a car that needs constant makeup oil.
Going to a higher viscosity will not decrease the oil life. In fact, for a given base-oil type, it will usually increase it, as NOACK decreases. Oil life is determined by the base-oil quality (like synthetic vs. dino), NOACK to some extent, starting TBN and TBN retention, detergents and the additive package, and oil-filter capacity. As an example, Mobil 1 0W-40 is one of the longest-life oils out there despite being fairly thick.
I checked Toyota
warranty, and yes, it's only 60,000 miles. Therefore, if oil consumption is a concern with this car, simply use a cheap plain 10W-40 to minimize it. You can in principle use 15W-40 as well and go with a 10,000-plus-mile OCI with it, which is even quite a bicker than 10W-40. 15W-40 is thick, has low NOACK, and has excellent TBN and TBN retention for low oil consumption and long oil life. I would recommend Mobil Delvac 1300 Super 15W-40. Let us know how a Prius runs with 15W-40 if you do so.
Or have it fixed for about $500 - 1,000 if it's a simple valve-stem oil seal issue.
