Originally Posted By: jfking106
Originally Posted By: Gokhan
Originally Posted By: xBa380
My dad has a 2010 Prius with 85,000mi on it. It burns almost 1qt every 1,500mi or so. We got the PCV changed but it made no difference. The oil change is coming up so I want to try a different oil to maybe control the consumption a little.
What oil to use though?
It takes 0W20.... I have been using Toyota 0W20 the entire time for this car. I thought of going to PP 5W20 or maybe 5W30?
Not good with the grades and what would be perfectly safe and all that. Need some help
Thanks!
3-year-old Toyota with less than 100,000 miles on it, burning too much oil. That engine requires a repair, not oil recommendation. Try to see if you can have it repaired under warranty while you can.
My 28-year-old Toyota with 249,000 miles on it burns virtually no oil with Toyota 0W-20 SN since I replaced the valve-stem oil seals.
Perhaps one of the valve-stem oil seals never clicked into place or broke during installation at the factory. Remove each spark plug and check for oiliness. There should be no oil on it whatsoever. There should also be little oil deposits (gray ash from additives). If it's oily, you have a broken or unseated valve-stem oil seal. Have it replaced at the dealer under warranty. If it's not oily but you have a lot of ash, it could be a ring issue.
That's along the lines of what I'm thinking: there has to be a manufacturer defect in that motor.
Still if it's consuming less than a qt in a 1000mi, Toyota is going to tell him to take a hike...
I'd try the M1 5W-30 HM to see if it improves...
