- Joined
- Dec 7, 2024
- Messages
- 67
i learned two lessons . Don’t skimp out on CVT drain and fills and also when chasing a squeak noise at idle it’s not in the engine bay check out the transmission.
126k. No prior service on the CVT.
Used to be very noisy whining noise at speed and at idle. Went into limp mode and put up some transmission codes.
Oil on transmission dipstick was black. Dropped the pan. Like half of a grenade exploded.
Replaced filter and cleaned out the screen. The whine went away it sounded great.
Drivability is good so far no hesitation and no slipping that I can tell. Maybe the belt damage is limited and we can get a few thousand more miles out of it.
It’s been a good little car, literally grandmas car for most of its life. Maybe if these cvts stayed limited to small under powered cars they’d have a better reputation.
Edit: we used valvoline CVT fluid which smells like death incarnate. But so much cheaper than the Nissan fluid.
