200hr oci for kubota L2501?
See
485hrs and the oil was probably changed once between 2016 and 2024.
I strictly run these on my older Kubota garden tractors. They always hold up well.
I've run these as well on my Kubota until they became hard to find. Have a 9688 on it now.
The orange ones are called orange cans of death. Might be fine for a little kubota, but some of the bigger diesels have a lot of oil pressure and can cause it to fail.
I've never been a fan about how car makers are stretching out oci. 10k miles seems to be the standard nowadays. Now back to the kubota, looks like the L2800 which was the similar sized model before the L2501 was brought out called for a 100 hour engine oil change interval, well the 2501 calls for a 200hr oci. Some manuals say 400hrs for some reason depending on whether it's the paper manual or the electronic manual.
Anyways, with that being said is changing a 6 quart sump on a little 3 cylinder 1.4 liter diesel every 200 hours sufficient? I'm definitely not doing 400hrs, this thing can eat a lot of dust when I break out the brush hog and go out and mow.
Do they list a regular vs severe interval listed? Does kubota offer a pre-filter to extend air filter replacement?
All I'm saying is I don't want to do a uoa and find a bunch of wear metal from break in. Doesn't really tell me much. The same thing happened with my diesel truck when it was new. Yeah the metal trended downward after a while but still. It sounds like 200hrs is the typical oci for this type of engine so I'm not really worried too much. You guys reassured me enough
I think that is reasonable. There are many posts of people who after 20k on a car, are still either having breaking metals in the oil, or they have an issue, either way is inconclusive, as far as OA can tell.
I would advise, that when you run the tractor, get it to pto range or higher, and let it run there, dont throttle down, unless you have to. These things are made to be run hard, running them softly is "bad". This might also help with break in..........that is what I did, when it was new, and still do today, after warmup of course.
I change the engine oil in mine every year, but I think usage matters more. I rarely go over 100 a year these days.
If you were using it 8 hours a day, on a continued basis, I would go the max suggested in the book. If you use it sparingly, do once a year. Cant hurt, and cheap insurance.
Thats about what I do per year, sometimes less. In earlier years I changed it every 50 hrs but got lazy so it now once a year.
i used to run my stuff quite a bit professionally on jobsites, and used the book interval. But these engines are about indestructable, provided you change the oil. a 5 dollar filter and 20 bucks of oil every year is not a waste of money.
A blanket oci question is impossible to answer properly imo. But at say 50 hour or one year, which ever comes second......should do fine.
In the extreme of this question, what if it took you 10 years to do 200hours, would the book oci be correct? I argue no.
I've cut open several of them with zero issues.
It's a D1105 on a Kubota B2620. I change the oil yearly. I probably put between 50-100 hours on the machine a year. Oil and filters are cheap.
Idk, at one point they had failures. May have been 20 years ago and I would imagine the issue was fixed whatever it was. Any long time lurker on here should be familiar with the term fram orange can of death.
what?
take off the foil hat dude.
The L2501 isn’t exactly a big Kubota IMO.
I have no idea what their operating oil pressure is, but I can guarantee you the little engine in my old G is spinning much faster than the engine in the L. I guarantee it gets hotter too.
The orange can always comes out looking great. I have some posted here.
