2009 Toyota Camry Transmission Filter Torque Specs
Southeast PA
I am looking to replace the transmission filter and transmission fluid on my 2009 Camry with the 2.4 engine / 5 speed automatic transmission but I can't find the torque specs for the transmission pan bolts, the bolts that hold the filter and transmission drain bolt. Can someone please help me out?
If someone has the exact specs, please share. I rarely use a torque wrench but when replacing a transmission filter and pan gasket I always torque to specs to avoid under/over tightening.
FWIW you are probably better of doing the 8 lbft with an lbin torque wrench set at 96 lbin, its going to be more accurate than a lbft wrench set down that low.
