Anyone know the torque spec for transmission pan bolts? I just had the transmission fluid serviced by the dealer and want to correctly torque the pan bolts to avoid leaks. Thanks.
Most times I try and use a torque wrench on pan bolts, the gasket squeezes out. I don't even try anymore.
Maybe you have a new, reinforced type, but the older ones could crack, and leak.
Do it by feel, and make them even. If it's not leaking, don't go crazy down there.
