- Joined
- Jul 18, 2022
- Messages
- 590
I'm diagnosing a Multiple Cylinder Misfire on 2009 Silverado 5.3 with 220k miles. It the threw a P300 code and is running rough at idle.
I took a data log using Torque Pro, cylinders 1,2,4,5 all have misfire history. Not wanting to go full parts cannon, we first replaced the spark plugs. (Cheapest option). Next I took a data log of fuel trims, O2 sensor voltages, and MAF sensor at idle after warmup. Catalyst temp is normal.
From what I was able to research, the o2 sensor readings are typical. Sensor 1's should cycle high - low, sensor 2's should be steady around 0.7v
There are 3 big dips in the o2 sensor 2 readings, is this a sign of bad sensor?
The LT fuel trims all indicate a rich condition (pulling fuel out). Is that normal?
The spot where ST fuel trims went to 10, does correspond with a valley in the upstream o2 sensor voltage.
Next steps is to throw coils and wires at it, but that's $300 proposition. So, I'm looking for a 2nd opinion.
