Does it matter that my heated O2 sensors take 5 minutes to heat up properly and start voltage transitions after a cold start? Even though it takes about 5 minutes for it to do so, it is reporting proper fuel trims (+/- 1%) while it is waiting.
The question is: Do I want to spend another $120 on the right O2 sensors or can I keep running my Bosch O2 sensors?
Here is a run I just logged 5 minutes ago:
Here was the run from yesterday:
Here is a run from the E-250 with the same OE o2 sensors as the Vic (DY-850):
Granted, I did not log open loop conditions for the E-250, but assuming it's based on a similar tune to the Vic, it should transition to closed loop within 40-70 seconds.
According to the Ford PCED ref values, the O2 sensors shall switch normally when in closed loop mode. So as far as I can tell, the E-250's O2 sensors start switching normally right after the transition into closed loop mode.
This is NOT the case with the Bosch 15717 O2 sensors. I am going to install DY-850s on the Vic and see if this changes. Even thought the fuel trims look normal with the Bosch sensors, it should heat up and transition within 50 seconds. A delay of 5 minutes is not normal and would probably yield low fuel economy.
