So normally a Post-Cat O2 sensor voltage should stay constant between .5V and 1V when a cat is healthy.
However, when looking at mode 6 data, The B1S2 O2 sensor also has a lean and rich test.
The lean test checks if the sensor can read lean between 0V and 0.1V
The rich test checks if the sensor can read rich, between 0.7V to 0.8V
If the O2 voltage doesn't normally reach this range, When is this test run? Is it during startup when the cat is warming up?
