Wow, I always thought Nissan were the most basic of engineering. Approaching 190k in our Juke and running a supertech filter. I've seen Jukes over 300K. Versa/Sentra manuals are the #1 taxis in Mexico now. Rogue must be an outlier for some reason.
unless you could snag a deal from Amazon or Walmart for the premium guard brand the way filter pricing has gone I’d opt for oe
https://www.z1motorsports.com/lubri...MI-eSOoay9iQMVV5paBR35LSRrEAQYASABEgIL6PD_BwE
if you want a slightly longer filter yes its equivalent to the Fram 7317. its 15 mm's longer over the 65F0ADoes this for sure fit a Rogue? I oversize my filter in my Toyota, but I know it fits. I wonder if this would get close to the wheel.
Thanks. That's helpful. I think I'm going to upsize but just wanted to make sure there was room. The OEM filter is so tiny. Like a lawnmower filter.if you want a slightly longer filter yes its equivalent to the Fram 7317. its 15 mm's longer over the 65F0A
Yes they sure are teeny filters. I have a stash of ecogard x4612s same height as a fram 6607 and pg4612s the pg’s have a little more height over the ecogards. I’ll take a picture of the two side by side for comparison. Bonus threw in a photo of a FL-816Thanks. That's helpful. I think I'm going to upsize but just wanted to make sure there was room. The OEM filter is so tiny. Like a lawnmower filter.
I’ve had 3 filters total and back to back gohners fail on my 09 Altima and 18 rogue. Shockingly the same filters, from the same case, have never failed on my 21 or 24 Altima. I still won’t use them though after that.Well it's got a high volume oil pump and it's a big moderate output 2.5L DOHC. My version had solid tappets.
I live in a cold - but not killer cold region in Southern NH
Winter starts and warmup drives ripped 2 pleats open on a quality $14 dollar FILTECH filter (I had posted pics)
And also, like a couple guys here, I had a long startup rattle on the Mexican made (Grupo Gonher) NISSAN
filters as the ADBV would fail by "inverting" and allowing drain back.
Simple parts like a filter should work; This is maddening, frustrating stuff .
-Arco
Very interesting thank you. I just got the oversized filters. Went with Carquest Premium. They are still small! Wow!Japan made MAHLE VS PENTIUS. the Japan made MAHLE’s are for the wife’s new rogue. Mexico made GOHNER filter has a silicone adbv the MAHLE have either nitrile or a black color silicone.
Did you get the equivalent to a 6607 or 7317?Very interesting thank you. I just got the oversized filters. Went with Carquest Premium. They are still small! Wow!
I'm not sure on those part numbers. I got this one: https://shop.advanceautoparts.com/p...protection-up-to-10000-miles-84356/10555794-PDid you get the equivalent to a 6607 or 7317?
That is the CQ Premium that crosses to the 7317 size. The Pentium PLXL 7317 also crosses to the 7317, and it a little longer than the CQ Premium 84356, but not enough to really worry about.I'm not sure on those part numbers. I got this one: https://shop.advanceautoparts.com/p...protection-up-to-10000-miles-84356/10555794-P
It's the CQ Premium 84356. Fits the GT-R and their trucks.
I’m going to say equivalent of the 7317I'm not sure on those part numbers. I got this one: https://shop.advanceautoparts.com/p...protection-up-to-10000-miles-84356/10555794-P
Well I just paid $9/filter at Advance Auto so I'd say that's a good deal!
I haven’t used this brand looks equal to a PG or ecoguard I wouldn’t mind though.Well I just paid $9/filter at Advance Auto so I'd say that's a good deal!
Is this another Premium Guard XL rebadge? Who makes this filter?
I would say no, based on the construction. Similar, but looks different. Plus Renken isn't a brand under the PG umbrella.Is this another Premium Guard XL rebadge? Who makes this filter?
It seems only way winter starts could explain your observations is if the oil pump had no regulator.Well it's got a high volume oil pump and it's a big moderate output 2.5L DOHC. My version had solid tappets.
-Arco
That splash shield is the worst. I can change oil on my 18 in as long as it takes to drain. When I do our 21 and 24, I set and drink 2 beers staring at it , trying to motivate myself to tackle that shield. At least the 2.5 doesn’t have to deal with the plastic oil pan that has a 60% chance of stripping everytime.Topic 09 Rogue, 99.9% sure, ~.5" longer 7317 and equivalent applications will fit just fine. In fact, 'personally' never seen a Nissan including those OM specing the shorty 6607 where the longer application did work. I did read where one member with newer generation Sentra had a hose obstruction that could prevent use of the 7317.
I would avoid the Gonher made Nissan OEM. Including my own, multiple c&p show an adbv defect which with use allows adbv collar to slide off its position and migrate down the outlet flange. In addition to no adbv function, allows for oil bypass too.
As an aside, I feel for owners of newer Nissan (since ~2020-21+) doing diy oil change. The entire splash shield must be removed to access the drain plug and filter. That involves removing ~20 cheap plastic push pin clips and a couple bolts each time.
