Thanks. . .I'll give WearCheck a try next time maybe. As I said before, I believe the fuel dilution was a sampling error on my part (engine didn't get hot enough, long enough). Fuel wasn't a problem in the previous UOA.
Originally Posted By: Robster
Originally Posted By: sunruh
its hard to find "bad" oils (well unless you use castrol gtx) but if wear metals dont rise, use whatever you want and be happy.
i tend to be more happy with great results from lower cost products.
So, you think the Mobil 1 will shear down as bad as the Rotella? I'll be doing a UOA on it, but it'll probably be next summer before I do it. . .
If your fuel dilution doesn't improve, it'll cause any oil to thin, including this M1 that you're using.
But some thinning over the course of an OCI is to be expected and not necessarily a cause for concern. After all, it doesn't appear to be hurting anything in your case.
As for the antifreeze issues, try a different lab next time, the one that actually does test for antifreeze by FTIR. Wearcheck comes to mind, and they're actually cheaper than Blackstone. There are others...
