2008 SRT8 Grand Cherokee oil
Central BC, Canada
Howdy guys, picked up a new toy, well it's used but new to me.
Full load, including dvd for the kids.
Factory fill is Mobil 1 0w40 as I'm sure many of you know already, but I don't have access to any Mobil 1 locally, it's big bucks to bring in. I/we use Chevron on site, but many of the syn oils listed on chevorn's web site aren't available in Canada.
5w20, 10w30, European 5w40 to list a few.
I have most if not all mineral based oils available, 5w20 (using that in fleet Fords, great value for service) right through 10w40. I would like to use the Delo synthetic, specs listed below. I can get Amsoil, Havoline, Castrol, Napa, Chevron, Pennzoil, but Chevron is my bulk lubricant, I can get it substancially cheaper than any other brands, usually 2-3 times cheaper, even by the barrel volumes, so if I can I'd really like to stay with them for complete lubricant application, much like all my fleet is already.
Filters, will be Donaldson or Wix. I also just installed a AFE stage II intake, dry filter with a rated 99.4% efficiency, so I'm confident of low contamination.
So what do you guys think, I shouldn't worry about cat contamination? I have sensors after the cats, if I didn't they would be gone :)
I'm tempted to do mineral, I change every 3,000 miles, so dirty/dusty up here, almost seems to be a waste of money, but I still have warranty, and that's another issue, will I be void running a diesel oil. In the owners manual it shows warm weather usage allows a 5w40, but not a diesel oil. Some are running 15w50, maybe in the summer....... now I'm rambling.
Thanks in advance!!
Mike.
APPLICATIONS
Chevron Delo 400 LE Synthetic SAE 5W-40 is a mixedfleet
motor oil recommended for all naturally aspirated
and turbocharged four-stroke diesel engines and fourstroke
gasoline engines in which the API CJ-4 or API
SM service categories and SAE 5W-40 viscosity grades
are recommended. It is formulated for engines
operating under severe service and a wide range of
climatic conditions.
Chevron Delo 400 LE Synthetic SAE 5W-40 is excellent
for use in new advanced engines developed to meet
2007 emissions standards and in engines equipped
with features like; four-valve heads, super-charging,
turbo-charging, direct injection, shorter piston crowns,
higher power density, intercooling, full electronic
management of fuel and emissions systems, exhaust
gas recirculation, and exhaust particulate filters.
It is formulated for superior performance with all fuels,
including low sulfur and ultra low sulfur diesel fuels.
This product is recommended for use in older engines,
as well as in today’s most modern low emission
designs.
This product is recommended for use in Caterpillar
engines in off-highway or construction applications
which require an API CJ-4 Service Category after
January 1, 2007.
Chevron Delo 400 LE Synthetic SAE 5W-40 meets:
• API Service Categories CJ-4, CI-4 PLUS, CI-4,
CH-4, CG-4, SM, SL
• ACEA European Service Categories E7
• major diesel engine manufacturers’
requirements
Caterpillar
Cummins
Detroit Diesel
MACK
MAN
Mercedes
Volvo
• engine test performance requirements
— Caterpillar ECF-3, ECF-2
— Cummins CES 20081
— Detroit Diesel Corp. Power Guard Oil Specification
93K218, 93K214
— Mack EO-O Premium Plus 07
— Mercedes Benz
MB-Approval 228.31
— MTU Category 1
— Renault RLD-3
— Volvo VDS-4
SAE Grade 5W-40
Product Number 271207
MSDS Number 24606
API Gravity 33.3
Viscosity, Kinematic
cSt at 40°C
cSt at 100°C
88.5
14.6
Viscosity, Cold Crank, C/Poise -30/62.5
Viscosity Index 168
Flash Point, °C(°F) 232(450)
Pour Point, °C(°F) -42(-43)
Sulfated Ash, wt % 1.0
Base Number, ASTM D 2896 10.3
Phosphorus, wt % 0.115
Sulfur, wt % 0.29
Zinc, wt % 0.127
That Chevron syn 5w-40 is probably really tough stuff. Different kind of oil from the Mobil 1 0w-40, but it might be a good option, especially if you can get it dirt cheap.
My other picks would be Pennzoil Platinum 5w-40 Euro and Amsoil 5w-40 Euro.
All else equal, I'd pick the Amsoil if it were me, but I wouldn't feel bad running any of them.
If I were living in CA, there is no way I would use anything but full synthetic. There must be some reason (prior bad experience without it) that Jeep uses Mobil 1 0W-40 as factory fill.
According to the Chevron website (people who complain about bad info from M1 should look at this pitiful website) Chevron Delo 400 LE Synthetic is also available in 0W-30. I think this might work better than the 5W-40 for that engine, especially in CA.
Good news, found out this afternoon the commercial distributor we have for lubricants just picked up Mobil!! Some pales of 0w40 factory fill on the way, thanks everyone!
