2008 Honda Odyssey oil and filter?
Olathe, KS
I'm going to start doing oil changes on a friend's Odyssey. I know it takes 4.2 qts of 0w-20. They usually take it to a quick lube place for whatever synthetic oil they get. The van is used for around town plus family trips. I would guess 10k miles a year. I do a yearly oil change on one of their other cars (a Ford Focus) and would like to do the same with the van. Thoughts on a good oil to accomplish this? Thinking that I would use a Fram XG for the filter.
**Edit. I do happen to have a fair amount of Pennzoil Platinum High Mileage 5w30. What about using that?
If the book calls for a 0W-20 use a 0W-20.
My brother has a 2007 and I use what's called for. His van runs fine.
I'm avoiding the undeniable reality of other oils not resulting in the destruction of your friend's engine.
Were it to fail, wouldn't you like to be in the position to truthfully claim to have used the proper stuff?
....even if he hit a gosh darn raised manhole? Who wouldn't want to eliminate the potential of guff? just sayin'
Yup. Any synthetic oil that the quick lube put in will likely be inferior to whats on the shelf at walmart. Even supertech.
Proper weight and api rating and your golden.
Mobil 1, Pennzoil Platinum, Castrol Magnatec, Quaker State Ultimate Durability, would be my first few chioces.
The Odyssey was specced for 5w-20 oil through the 2010 model year. Honda later decided that 0w-20 was acceptable for those years. But I prefer to use 5w-20 in the 2007-2010 engines unless you live in a location with frigid winters. Another plus for using the 5w-20 is if the van has higher mileage.
So I'd use whatever SN rated synthetic is on sale, and go by the OLM or one year for your change interval. My 2007 Ridgeline now gets about 5-6K miles a year and uses virtually no oil between changes.
If its a VCM engine throw the book away and use 5w30 or 0w40 in that engine. No, the engineers didn't get it right on this engine, the clowns who dreamed up with this nightmare (they have been sued for it) need to go back working at a McDonald's drive through like they did in high school.
Get a VCM muzzler for it.
My `06 EXL Odyssey with cylinder deactivation holds 4 3/4 quarts to bring it to the full line for an oil change with filter. I have run everything from 0w-20 to 5w30 and others run 0w-40 with success. The only difference I can tell is the engine is a little noisier with the lighter oils, but seems slightly more peppy with the 20 wts. as well.
Don't run the oil too long as these engines with cylinder deactivation are tough on oil. Mine is varnished/little sludge even though I follow the OLM and run full syn. oil. I have 141,000 on mine, owned since new.
Originally Posted By: Trav
If its a VCM engine
We had an '05 Odyssey w/o VCM. I believe they added it in '06.
Regarding muzzlers, you're a mechanic, yes ? If so, do you recommend your customers add one ? If our Odyssey had VCM, I would have added one myself. Just curious how you deal with it.
Old VCM inhales - to many stages and new at the time loose algorithms.
New (2017) VCM has been great so far. Engagement is barely if at all perceptible.
Only 2 choices 6 and 3 which is easier to tune the engine mount and map loads to.
The old 6-4-3 was all over the map and the mounts never kept up.
Ive seen little to no oil consumption after the first 3500 miles (break in) so it doenst seem to be causing any consumption.
UD
The 05 had it on the Touring model and one other IIRC, yes by all means a muzzler is highly recommended for these engines.
The cylinder deactivation cause lots of stress on those $600 engine mounts, the front cylinder to over work and cause horrific deposits and varnish to the point the clog the spool valve causing all sorts of problems and the engine to run on 3 cylinders all the time.
You should change the oil every 3-4K with a synthetic on these engines and change the grossly undersized PCV (look at the picture of the small pcv opening, sorry for the poor focus) every 15K.
Here is a touring with VCM.
Mine uses 1/2 qt every 2500 miles like clockwork (regardless to brand or weight of oil). I average a 5000 mile OCI. So I add 1/2 qt. half way through the OCI.
Touring, EX and EX-L have VCM. LX did not. My 2006 EX-L has 190,000 miles and the VCM spool valve, valve train and valve covers have no sludge build up at all with only a slight varnish. I have used Fram Ultra filters and either Mobil 1 or Pennzoil Platinum 5w20 for every oil change, following the maintenance reminder intervals. Keep a close eye on the PVC. I have cleaned or replaced it 4-5 times, so once every 40k miles or so. I have had no problem with the VCM system or engine mounts so I consider myself lucky!
Variable Cylinder Management
The system turns off cylinders at times to theoretically improve fuel economy but in reality its almost useless and possibly does damage to the engine and other parts depending on driving conditions, the muzzler disables the system.
  • Like
Reactions: JC1
Thanks for that. So, is the muzzler a reprogramming of something? ....or is it a physical fix?
Gotta see if my brother's 2007 Odyssey Touring has VCM.
It plugs inline with the coolant temperature sensor, and adds enough resistance to fool the ECU into thinking the coolant temperature isn't high enough to activate VCM. Supposedly it doesn't throw the coolant temperature reading off enough to cause check engine lights.
Was 0w20 even a thing back in 2008? Not that there is really a difference between 0w and 5w20, but I'm pretty sure our 2007 Honda Odyssey LX recommended 5w20. I used various 5w20 and 5w30 in it and a bunch of different brand oil filters the 6yrs we owned the van. Like said, the LX model didn't have VCM
IMO, if you really want to maintain this 2008, I'd do some drain/fills of the ATF as well.
The original specs for the 2008 Odyssey is 5W-20 but you can use 0W-20. Like others have stated, if it has the VCM technology, you may want to shorten the OCI to 5k miles. As far as what oil, I would use whatever synthetic oil is on sale at Walmart that week. All meet/exceed the oil requirements for the van and will only cost at most $23 for 5 quarts, which is a bargain. Good Luck.
2010 Odyssey LX owner here. I’ve used Pennzoil Platinum High Mileage 0w20 in my van, which seemed to be fine, but I’m a Valvoline guy and I’ll be using MaxLife 5W-20 blend going forward. I’m currently using up my stash of FRAM TG7317 filters. When those are gone I’ll probably buy more, or perhaps an Orange Can. My OCI is 6 months which usually works out to about 4,000 miles.
Update:
Did a valve adjustment on my `06 Odyssey EXL. Current 165,000. First valve adjustment. Keep in mind I mostly did `5000 mile oil changes with synthetics. Under the front valve cover was a horror. Varnish sludge, it was gross. Looks like I totally neglected it, but oil changes were following the OLM or less. 1x went 310 miles over, returning from a trip. 1x ran 8000 miles, but that was with an extended performance synthetic, that should have been a breeze.
Weights run over the years. 0w-20 to 5w30. All synthetic, except 1x synthetic blend.
This van does soccer mom duty, lots of short trips. Occasional long trip too. But maintenance was never neglected. Being a car guy it was embarrassing how bad it looked. Definitely a engine design flaw. Under the rear valve cover was 70% good.
By the way it took me 10 hours to do the valve adjustment, PCV, throttle and plenum cleaning. FUN! Sorry no pics. Not as bad as the pics from the post from Trav. But still bad.
