2007 Yamaha Grizzly 350 low compression
is that a honda atc185 ?
i know its not a 70,90,110,200x,250r
well at least you have brakes and a motor but now need a camchain
if you can double check the teeth on the crank n make sure they are not sharks teeth
and just realize that then you re-torque the cam caps after having to lift them to put the new cam chain on, it really is that low of a torque value (usually under 10nm)
Its an 1982 ATC200 I think they only made it for a couple years. Its been in the family since the early 90's and the motor/trans has never been apart.
Grizzly has a new cam chain and thankfully the teeth looked good on the crank and the cam sprocket. I didn't actually take the cam out of it so nothing to retorque. Thanks!
