I’m working on getting a Yamaha vino 50cc 2t running that’s been sitting 4+ years. It’s my understanding that it ran when parked. I thoroughly cleaned out the gas tank & carb (also installed an in-line filter), and hoped to take it for a test ride but couldn’t get it to run. It would fire up and high idle for a few seconds on carb cleaner shot down the intake, but couldn’t stay running by itself. I noted that when cranking on the electric starter, I could see fuel atomizing in the venturi of the carb (air filter removed) but the engine wouldn’t fire. The plug would never really get wet with gas even after extended cranking, and it didn’t seem to develop much vacuum.
After further investigation I discovered the rubber manifold/reed box below the carburetor is extremely cracked & rotten, I think giving enough of a vacuum leak to prevent the engine from running. Planning to replace/reseal this and try running it again.
I didn’t have a compression tester at hand, but my thumb-in-plug-hole estimate felt kinda weak in terms of compression. I felt more “suck” than “squish” for sure. Being unsure the state of the engine, I removed the exhaust to get a look at the piston. I think the piston/bore look alright (visible crosshatch, no piston skirt scoring) for having about 5000 miles, but the lower ring looks broken/recessed in the groove? I forgot to take a picture, but the old plug is a good brown color & pretty oily.
I’m hoping this guy will run and ride with the intake leak fixed, but I’m getting worried that a top end job may be necessary. Is there any harm in running it like this, assuming it will run? Could a lean condition from the vacuum leaks have caused the piston/ring issue originally? What’s the life expectancy of a motor like this anyway? Thanks for any advice, I will update when I work on it next
