Decided to get the 2007 Honda accord with the 2.4 engine. So what trans fluid should I use? The orginal Honda fluid or something else? I would like to change the fluid.
Thanks
Changed the Trans fluid this weekend, very easy. Also saw there is a trans filter on top of the engine on drivers side. Found part # and gonna change it.
I think you'll find this to be the case with every maintenance point on your Honda. I own two and have found them to be very easy to own. DIY maintenance seems to have been designed-in from the beginning. All fluid sumps are easy to access. Parts are easy to find and are generally inexpensive. I find the cars to be screwed together pretty well, with smart design evident throughout. I'm sure you'll enjoy it.
