2005 toyota camry 4cy
Struts, shocks, rear link bushings, front CV and bearings..
Get it on a lift.
Terrible driving cars, but good for a kids first if that's what it is.
I don't recall what years had the E throttle pedal issues.
Not familiar with that issue, but I know the mechanical cable on my '99 likes to stick (closed). I keep meaning to look for some pivot point to lubricate; I suspect the problem is under the dashboard, someplace.
Originally Posted by clinebarger
I've done quite a few head gasket jobs on 2AZ-FE engines & had to Time-Sert the head bolt threads on more than a few. Then you have the oil burning issues.
HG issues may be a hot climate thing for all I know?
The 1MZ-FE/3MZ-FE V6's was the bulletproof engines for that year model.
I think the head bolt issue is mostly on the earlier 2AZ's. By 05 those are usually not problematic.
The oil drinking 2AZ's are the ones that took 5w20/0w20, those were not introduced into the Camry until 2007.
Koni makes shocks for the 5th gen Camry
I've done HG jobs '05 '06 & '07 2AZ Rav4 & Highlanders. For whatever that's worth.....Not sure I'd I call it widespread or problematic.
Originally Posted by slacktide_bitog
I HATE the 1MZ :mad
You make that abundantly clear every time a 1MZ is mentioned
And I've gotten over 400K on mine with no abnormal consumption or other weirdness yet
