I had suspected a leaking head gasket, so I sent in a sample. Unfortunately, it looks like I'm right. This is the first analysis I've done on this vehicle, and all the other numbers look "great", so at least that's a bit of good news.
For what it's worth, leaky head gaskets aren't that uncommon in these engines (1GR-FE). From what I've read, it usually happens around 120k miles. Toyota has new part numbers for the head gaskets, but I don't know if that means that they've updated/upgraded them or not.
Comments? Thanks - Chris
"CHRIS: Based on the level of potassium present in this sample, you're probably correct about your head
gasket leak. Potassium and sodium are the elements we see that make up coolant. The good news, though,
is that you've caught the leak early. Wear still looks great compared to universal averages, which are based
on 5,300 miles on the oil, and insolubles are low enough to show that the oil hasn't started to turn to sludge.
For now, you may be able to keep wear under control with short oil runs (and watching your coolant level).
Change this oil within 1,000 miles."
Code:
Aluminum 4
Chromium 0
Iron 5
Copper 1
Lead 0
Tin 0
Molybdenum 54
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 112
Boron 25
Silicon 14
Sodium 12
Calcium 2733
Magnesium 13
Phosphorus 781
Zinc 864
Barium 0
SUS Viscosity @ 210* F 55.9
cSt Viscosity @ 100* C 9.05
Flashpoint in *F 410
Fuel %
Antifreeze % POS
Water % 0.0
Insolubles % 0.3
Code:
Aluminum 4
Chromium 0
Iron 5
Copper 1
Lead 0
Tin 0
Molybdenum 54
Nickel 0
Manganese 0
Silver 0
Titanium 0
Potassium 112
Boron 25
Silicon 14
Sodium 12
Calcium 2733
Magnesium 13
Phosphorus 781
Zinc 864
Barium 0
Fuel %
Antifreeze % POS
Water % 0.0
Insolubles % 0.3
