Good morning bitogers!
We have been experiencing extremely cold weathers past 3 weeks in Manitoba, avg high - 26C avg low -35C. I've notice a leak from the top of the radiator, most likely from the top hose hose connection. There are coolant splatter residue on the top hose, and down the fan shroud. I've already purchased a denso unit and coolant hoses from rockauto.
I topped up my radiator twice in the 3 weeks (2x 4-5 oz coolant), but it seems like I lose more than I put in. Also it doesn't seem like the system is pulling any coolant from the reservoir as it has been full since I noticed the leak. Do I have to turn on the engine and top up? Or is that just to burp air out of the system?
Prior to noticing the leak, the engine would not reach operating temp(crvforums says 180-190F/82C-87C). I'm not sure how accurate torque pro is, but the coolant temp never goes above 81C, even driving for 45 mins. I can see the needle on temp gauge decrease when i'm idling at a red light (torque pro will show 77C and dips to 70C), and raise when I'm driving. If I turn off the heater, the temp do not fluctuate, and will reach 81C quicker and hold. Would this mean my thermostat is faulty? Or its just to **** cold to warm up an aluminium block? Or the radiator was already compromised and had a small leak and got worse?
