code:
Esso XD-3 Mobil Delvac Castrol RX Esso XD-3 Esso XD-3
0w40 15w40 15w40 0w30 0w30
KM's on engine 14000km 22000km 28400km 37100km 47000km
Time on Fluid 8000km 8000km 6400km 8700km 9900km
Time on Filter 8000km 8000km 6400km 8700km 9900km
Fluid Maint Changed Changed Changed Changed Changed
Filter Maint Changed Changed Changed Changed Changed
Iron (Fe) 45 39 50 33 27
Lead (Pb) 1.2 0.7 0.3 0.8 1.1
Silicon (Si) 64 31 20 16 14
Copper (Cu) 10 6 3.6 2.9 8.1
Chromium (Cr) 1.1 1.2 2 1.3 1.2
Nickel (Ni) 0 0 0 0 0
Titanium (Ti) 0 0 0.2 0.1 0.1
Silver (Ag) 0.4 0.4 0.4 0.3 0.4
Aluminum (Al) 1.3 4.3 6.3 3.2 2.9
Tin (Sn) 1.3 0.9 0.2 0.5 1
Sodium (Na) 3.4 0.8 3.1 1.8 0.5
Potassium (K) 12 4.1 5.5 2.3 2.5
Boron (B) 3.6 24 7 4.3 2.6
Barium (Ba) 0.7 0.3 0.6 0.2 0.1
Molybdenum (Mo) 0.6 27 7.2 3.2 1.2
Magnesium (Mg) 9 315 84 27 14
Calcium (Ca) 2938 2534 2819 3003 3144
Phosphorus (P) 1005 1099 1151 1026 1150
Zinc (Zn) 1192 1277 1277 1213 1227
Sulfur (S) 3143 3313 4387 3556 3764
Manganese (Mn) 1 0.8 0.8 0.6 0.5
Vanadium (V) 0 0 0.1 0 0.1
Fuel(%) 3 4 3 4 5
Glycol NEG NEG NEG NEG neg
Soot(%) 0 0 0 0 0
Oxid(PA) 63 63 163 63 68
Nitr(PA) 64 73 195 73 82
Sulf(PA) 56 56 191 56 56
ZDDP 17 18 18 17
TBN 8.06 8.19 7.31 7.42 7.31
[email protected]°C 9.8 12 11.1 10 8.9
VOA [email protected]°C 15.7 15.5 14.8 12.1 12.1
Once again, high fuel in the oil and lowered viscosity. Oddly enough though, the iron per km is lower, silicon is lower, lead is the same and only the Copper has went up.
Any ideas? Do I have a problem with the injectors?
![[Bang Head]](/forums/graemlins/banghead.gif)
I don't seem to be "making oil", my oil level does not go up throughout the interval, even though there is supposedly almost 1 quart extra of fuel in there, unless I burn off oil at the exact same rate as I'm leaking fuel into the oil.
![[I dont know]](/forums/graemlins/dunno.gif)
The truck runs great, no romps or stumbles or hesitation. I can't tell from the dipstick if there is fuel in the oil.
My driving habits are: on Fri and Sun I distribute and pick up signs at various intersections, for about 8-12 hrs per night, 350km per night. So I drive to one intersection, stop in park for 1-3 min, put/pick up the sign and then back in to the next stop. The stops can be 50m away or 500m away. But I also do regular street driving and hwy driving during this time so it's not a straight 10 hrs of stop and go. During the week, it's "normal" driving, mixed city and hwy.
I'm going to request that Ford checks the injectors but I'm afraid they will say nothing is wrong and that this is "normal" contamination for vehicles that idle more than "usual"
Any ideas/suggestions? Why would I have lower wear with so much fuel and lower viscosity?
![[Confused]](images/icons/confused.gif)
Is idling in Park different than idling in Drive with the brakes on?
![[Big Grin]](images/icons/grin.gif)
Other than maybe getting an rpm control device to raise the rpms during my idling time, I don't know what to do.. Should I turn the truck off every time I get out of it to put the signs out? It would be a PITA to do that 200 times per night..
