Drove a 2003 motorhome today with a Ford F53 chassis and a V-10, and 35,000 miles.
Two things that bothered me.
1) The steering wheel was at the 1 o'clock and 7 o'clock position... instead of at 3 and 9 o'clock. Also, I felt some wander in the front end, and also what I can only describe as a hard spot, where the steering got stiffer when I was trying to make small corrections at 55 mph, and then once it would get past the hard spot, and it would free back up.
2) The other issue was that there was a grumbly, rolling resonance in the driveline starting at 58mph, that didn't go away above 58. I took it up to 65 and never lost it. Badly out of balance tire? Driveshaft issue?
Unit has 19.5" BFG tires on the front, Coopers on the rear. They are 4 years old with 15,000 miles on them.
Other than that, it rides like it is the chassis for a FedEx truck... wait... it is probably *IS* the same chassis.
