90K miles, time for the timing belt.
I took it in on Monday and had them change the TB, also, I had worn brake pads on one side, so something was wrong and I didn't have time to get to it, so I asked them to look at it, and to look again at the intermittent vibration.
Well $428 later, I had a new timing belt and serpentine belt(s), the RHS brake hose was replaced (I had already replaced the pads with some I had on hand) and they located the bad tire and mounted the spare on it's alloy wheel and mounted the bad tire on the steel spare wheel.
I am glad I have a good indy mechanic. It was a bit frustrating he didn't find the bad tire the first time, but it was so intermittent, that when they balanced out the tires in the Summer of 08 it would go away and then come back.
I guess the tire got bad enough for it to be obvious now.
oilBabe says the van drives 1000% better.
