Originally Posted By: mechanicx
One more question, if I'm looking at the picture right, was it the last rocker to the viewer's left in the top photo that was loose? I think that is the #5 intake. And there is another rocker to the left that is not visible in the photo right?
I think starting from cylinder 1 to the right EI EI IE.
You are correct on it being the #5 intake from what I was looking at.
2 days ago pulled the front valve cover to check the torques on all of the front rocker arm bolts but none seemed loose to begin with.
Changed the oil out to get rid of the likely excess fuel/fuel damage, drained and filled the coolant since I had to take off the bypass pipe anyway. Nextgen 10w30 is in there now, replacing a short (2300 mile) run of PP.
Here are a few pictures of the front rocker arms.
Valve cover was so clean I didn't even bother wiping it down...
For a late model car, it's very simple and straightforward to work on. Very well designed and decent layout. I think I used the same socket for half the bolts on the car through this project. If my 1993 GM truck was this simple I wouldn't end up with a complete metric and SAE socket set out by the end of every task.
