2002 Escort using 0w40
MT
Is it alright to continue use of Mobil 1 0w40 Euro + Lubegard Biotech Engine Treatment or should i switch to rotella t5 10w30 or t6 5w40 or maybe havoline pro ds i hear supertech full synthetic is a good one as well or QS HM DEFY or GC 0w40. What do you all think?
winlin
MT
Just wondering if its alright to use in cold temps etc, or if the 0w40 is to heavy for cold temps like in the negatives.
winlin
MT
Originally Posted By: OneEyeJack
why are you asking the question? Is there a problem? What's going on?
What do you think about it for cold weather? or Which one has great additives in it already?
winlin
MT
Originally Posted By: crazyoildude
you have a good engine there they seem to run well on everything
What oils have you tried?
Regina, Saskatchewan, Canada
A 0w-40 is not too thick for cold temperatures. In fact, at really, really cold temperatures, it's going to be thinner at startup than any 5w-XX or 10w-XX.
MA
Why didn't you stick with the 5w20 oil that's recommended by the manufacturer? I have a Ford Taurus which calls for 5w20 and I've used that pretty much all the time, up to 200k now. If anything, I'd be tempted to try 0w20, but that's about it. Thicker isn't always better especially on an engine that isn't designed for it. I'd also stop wasting money on additives too. They are not recommended by the manufacturer.
NEUS
M1 0w-40 is fine for your car and fine for cold temperatures. The 0w-30 might be better unless you need 40-weight for some reason. If it burns or leaks oil, the high mileage 5w-30 is the way to go. Skip the additives. That oil's great as it is.
winlin
MT
I have run 5w30 full syn before, i know i dont wanna run 0w-20 or 5w20 cause thats when the engine gets a little noisy or some oil that shears alot after 3k on conventional i switched to full syn around 50k cause it would use a little oil but doesnt burn anything now.
Ponte Vedra Beach, FL
Another option...You may be able to run German Castrol 0w30 in your vehicle during the winter. Just make sure that you can run a API-SL.....if it is under warranty. M1 0w30 is another option.
pbm
New York
Is that a ZX-2 Zetec or the regular Escort? I'd drop down to M1 0w30 if you want to go thicker than spec. and I'd drop the additives....they aren't needed with these top shelf oils.
North Carolina
Warren Performance Products (Nebraska) package most of the Supertech, but Mobil, Sopus, and Citgo might also bottle it in some markets. Run whatever you want as all listed are good. I run Havoline and a Rotella T5:10w40/5w20 mix in my "Old-baru". You can try the new Xw-30 HEDO oils if you can find them. Mobil, Shell, and Chevron have been moving that direction and they are normally SM/SN rated.
