Hi everyone,
Here is another sample from my mother's Venture Van. As you can see from the previous UOA's, the van had an internal coolant leak, which has since been fixed. The two most recent UOA's are after the gasket repair (the second from the left was the first fill of oil right after the repair), and the left most (bold) column was just drained and sampled a few weeks ago. There was one fill of TSO that was not analyzed between the most recent and the second most recent UOA's below. Before this last fill of HDD was added, Amsoil Engine flush was used to clean things up prior to draining the TSO and adding the HDD.
Here are the vehicle particulars:
2002 Chevrolet Venture Van
3.4 L V6
Amsoil EaO29 used in all UOA's
AC/Delco Standard Air Filter used in all UOA's
The van does mostly short trips (only a couple of minutes each), with some long distance boat trailer towing thrown in there every other weekend or so. Some highway driving occurs about once a week (in addition to the trailer towing).
Here are the analysis particulars (most recent to the LEFT, oldest to the RIGHT):
Date Oct9/07 Feb11/07 Sep9/06 May2/06 ?
Oil Type S3K HDD TSO TSO TSO TSO
OCI (miles) 6650 4300 5700 6250 6250
Total miles 100,500 88,000 81,300 75,600 68,800
Iron 15 24 15 20 34
Chromium 1 5 1 0 1
Lead 8 6 5 5 9
Copper 22 17 23 27 61
Tin 4 0 0 0 0
Aluminium 12 12 9 10 7
Nickel 0 0 0 0 0
Silver 0 0 0 0 0
Silicon 39 33 56 57 68
Boron 2 8 9 18 27
Sodium 0 19 67 70 25
Potassium 0 0 21 25 0
Magnesium 23 35 107 367 972
Calcium 4211 3404 3724 3210 2460
Barium 0 0 0 0 0
Phosphorus 1237 698 1009 1009 1011
Zinc 1533 832 1054 1145 1473
Molybdenum 8 3 4 6 2
Titanium 0 0 0 0 0
Vanadium 0 0 0 0 0
Fuel b> Viscosity at 100 C - 11.87 11.21 11.88 12.01 15.05
Water 0 0 0 0 0
Coolant NO NO YES YES NO
TBN 3.48 4.26 4.14 3.36 4.06
Oxid 16
Nitr 22
Copper, Lead, and Tin are up in this report compared to last UOA. This is after the Amsoil Engine Flush as well. Do you guys think this is just residue cleaning itself out or is there still a problem here? Coolant is not leaking anymore, which is good, but it seems that the wear metals are taking quite a while to settle down.
Thanks for the comments in advance as usual
3.4 L V6
Iron 15 24 15 20 34
Chromium 1 5 1 0 1
Lead 8 6 5 5 9
Tin 4 0 0 0 0
Nickel 0 0 0 0 0
Silver 0 0 0 0 0
Boron 2 8 9 18 27
Barium 0 0 0 0 0
Titanium 0 0 0 0 0
Vanadium 0 0 0 0 0
Water 0 0 0 0 0
Oxid 16
Nitr 22
![cheers3.gif](https://bobistheoilguy.com/forums/images/graemlins/cheers3.gif)
