quote:
Originally posted by JHZR2:
5w30 shouldnt be too thick at 30F.
I believe...
JMH
Ah, yes, that is perfect.
Ok, What you are seeing is the case for a engine oil flush.
Seems that all 4.3Ls will need one after a while.
Grab a bottle of Gunk engine flush and dump it in your oil and allow the engine to idle for 30-40 mins and then dump the oil and replace with fresh oil and a fresh filter.
If you want to be really thorough, you can use the flush with cheap oil and a junk filter to do the job even better.
I did it on my 1995 4.3L and after 40 minutes, when I dropped the oil, it was black and the filter was plugged and guess what, the knock was gone as well.
Good luck, if you need anymore Blazer questions answered, come to Automotive forums and join the Blazer section, we answer close to 100 questions daily on Blazer issues.
