- Joined
- Feb 28, 2010
- Messages
- 1,663
Hello folks, some of you that have read my posts in the past know that I have had a really hard time trying to understand which oil is "better" to be used in my 06 Lancer Evo 9. There are always many variables, but I have pieced together some reasons that engine builders of the 4G63 (engine used up to evo 9) recommend the use of a 50w oil vs the OEM recommendation of 10/30.
So here is what I have learned so far, and I would like some input from any engine builders here or just guys that REALLY know oil to see if these are valid points. Unfortuneatly I do not have any video or pictures of what I saw, just a description of what I saw and heard. Again, this is for my own personal knowledge.
My current oil is Redline 5w30 of which some of you know. I have been BASHED more than you will ever know for using this viscosity in my car and here are some reasons to why:
I just came back from a road trip to have my cars suspension receive a nice alignment from a well known and respected race chassis tuner. We got on the subject of oil for DD (in reference to Daily Driven) duties as well as race duty (meaning a closed curcuit timed event not street racing) and my friend that owns the shop threw in his 10 cents.
I stated I was suing Redline 5w30 oil in my car and when I said that the mechanic actually dropped his wrench on the floor and said "WHAT" and there it begins. I begun by stating about start up wear, about the POE based oil, the additive package, the HTHS and so on. EVERYONE IN THE GARAGE SHOOK THEIR HEAD. So I said, ok, what am I doing wrong and why?
My friend and tuner (engine builder as well for the 4G63) first started by showing me an engine that was recently pulled from an Evo running 10/30 oil. Though the internals where fine up top (valvetrain) and the crank look good and so did the pistons, the oil pump was not so fortunate. The oil pump had its teeth sheared off, and the crank had wobble in it. He went on to say that what happens with the 30w oils in the 4G63 is that in High RPM (6-7k plus) while under boost the 30w oil loses oil pressure, as this is happening, the oil pump takes the grunt of this that causes the gears in the oil pump to basically strip, ultimately causing engine failure.
As I thought this to be a fluke, I said ok, on a race motor I can see that, but not a "OEM Stock" block. He said WRONG!! THIS IS AN OEM STOCK BLOCK. OOOHHH I had nothing to say. This particular Evo was tuned, had bolt ons, and basically very similar in mods to my own car. So I started saying, about how is that possible? wouldn't a lighter oil be able to circulate quicker to prevent this? I was told no, not exactly. The oil is basically starved at high rmp while using a lighter viscosity.
The Chassis tuner who also races his own persoal Evo agreed and said he has seen allot of this. My mouth dropped. This is a very respectable person. I asked him what then? He said what happens like my friend stated is that oil pressure drops off significantly with a 30w, and though it is for use by Mitsubishi, he stated that was for MPG's not for durability reasons to why Mitsubishi chose that weight oil. Again, my mouth dropped.
So I asked the chassis tuner what he uses. His stock Evo. Brad Penn 20/50 his race Evo straight grade 40 or 50 Brad Penn.
I asked my Tuner what he uses. His personal Evo 20/50, his race Evo 20/50.
In the end I lost the conversation, the proof was right there. They both said, if I continue to use a 5w30 or a 10/30, you may not have a problem in the crank, or the valvetrain, or even the turbo, but your oil pump will fry sooner or later. Its up to you they said. Lose 4-5whp and some MPG's by useing the 20/50 and have engine durability, or use the 30w have a little more power and more MPG's but risk your motor in the long run. Wow.
So when I came home I did some more research on line and found this. I found TONS agreeing with this guy, but I will just use the one guy to save space.
question: What oil would be best used? a 30w?
answer: Too thin, as are most of the oils listed in this thread. There is a very specific reason you run 20-50 in a 4G63 and I have already mentioned it
Despite what some salesman might lead you to believe the 4whp you lose from thicker oils isnt worth a seized oil pump...which takes out the bottom end. Once it strips the timing gear then it slams valves, I have a car right here right now that went through this. Any Evo that is being used needs the thicker oil especially at higher rpm
question: so you recommend using 20-50 even when the car is stock from factory? I wonder why mitsubishi didn't think about that.
answer: I have a stock motor, I run 20-50 for the reasons listed above.
let me define my use of the word "used" in the phrase "any evo being used". If you run car over 7k and boost it at the same time then I recommend 20-50. But what do I know right?
question: but the oem specs shouldn't require a 50w right?
answer:
Piston to wall- 0.0025 (stock) .006 on a built motor
Thrust- 0.0015
Bearings- 0.002-0.0024
15-50 will work as well. I have used 15-50 before in various turbo engines, 5-50, 20-50, but the main thing is having the thick component weight to the oil. I use 20-50 valvoline in my stock motor thats in the car right now.
question: so whats the deal?? too much power for a 30w on an OEM block? Turbo?
answer:
Its not power its RPM. Bearings and the oil pump shaft dont like RPM on thin oil. The only tolerance that changes in a built motor is the piston to wall and that has very little to do with the cause of the failures I am describing.
Ask Curt Brown about his oil pump shaft There are very specific reasons I say what I do, I never say something that does not have multiple failures linked to a root cause then cured by something with direct evidence.
So basically that is what is happening. I have SEEN it, and now im very concerned about this. I was thinking of switching to Valvoline VR1 20/50 synthetic since I can get it anywhere in town and its affordable. Did I do wrong by buying the Redline 5/30?
Oil Gurus, Your opinion? Out of curiousity if anything. Thanks for your time in reading, and your experience.
Jeff
answer:
Thrust- 0.0015
answer:
Jeff
