Originally Posted By: djdino
Originally Posted By: dparm
Out of curiosity, why did you select the 10w40? Do you have oil temp & pressure gauges?
Motor is internally stock and running Mivec so thought it best to use a 10W40, and the garage that sponsors me stocks Motul, have a Racepak Dash logging stock perameters and can run oil temp and pressure and probably should just been slack and haven't hooked up sensor.
Not sure what kind of "racing" your doing with your Evo, But if your running a stock bottom end and stock turbo, you don't need the 40W unless your oil temps are over 100C like all day long. You are losing spool up time running a thicker viscosity which really hurts the evo. If your running an FP Red or Black, then you will need a 40W because I believe FP requires the use of it. I may be wrong, it just may be they require allot of ZDDP, so look into that. I solo II my Evo 9, OEM block and Turbo, Put 320whp on the mustang dyno and I never see 100C plus on the track. In short tracks like Streets, or small solo II courses, you need quick spool up time. Thicker viscosity causes slower spool up times. So unless your oil temps are hot on the track, or your running a built motor, 40W is overkill and may be costing you time on the track IMO.
Additonally, if your running E85 I would use RP XPR 10/40, or Amsoil Dominator 10/30 both of these oils are formulated to hold up quite well with alcohol fuels. I personally ran RP XPR 10/40 in my Evo while running WMI. Help up very well to the alcohol. The XPR 10/40 was specifically designed for use of alcohol type fuels. This is the only 40W oil I would recommend simply for that reason. Otherwise, run a 30W and do some oil tests to check how the oil is holding up.
