Hey Guys,
I am just confusing myself more and more with oils and have been reading many things for the past week.
I have a 2000 wrx that is built as a track car.
Has forged bottom end, race bearings, td05-20g turbo and big injectors.
Also a drilled crank
Running about 200kw atw.
On recommendation of a previous tuner (who knew his stuff about subarus) i was using mobil delvac MX which is a 15w40 oil and it is actually aimed at diesels.
This did not make a lot of sense to us, but he knew what he was talking about so i trusted him.
Since then there has been a falling out with that tuner and we have practically rebuilt the car (same engine just has sti cams now).
And the couple tuners i have talked to have said its pretty weird to be using a diesel oil and recommend a fully synth.
I was running out of time and before her tune and ended up putting in castrol edge sport 10w60 just to get going, however after further reading i am thinking this may be to thick for my engine.
I am based in australia, and generally my oil temps on the track will get between 100-120c depending on the weather outside.
So i have turned to the knowledgeable members of this forum to help me out
If you could recommend something that is available in australia that would be good.
Reading through a 7 page topic on a lancer forum where there was a guy from Opie oils saying 10w-60 is to thick for most applications, and was recommending a 5w-40 for a lot of the evo owners. But i am still confused about what i need. (http://lancerregister.com/showthread.php?t=244716)
If you could please recommend a weight and a brand that would be incredible!
Temperatures would rarely be below 0c when having to start in the morning.
Thanks in advance!
Thanks in advance!
