After 3k miles.I believe the LSJr R&P vid pistons were all the same. But it’s been a while since I watched it.
Those were the ones!
Yup, you are 100% right, those are not the same pistons, there are several differences between the top and bottom row.
They said "modified IIIH", but I know what you're saying...I really don't know.Or 90 hours at the IIIH testing parameters, 3600 RPM or whatever it is.
I still think the deposits that IIIH accumulates (left) may be easier to remove compared to build up over ten years in everyday driving.
Furthermore, the 90 hours at 3600 RPM for the right piston is not something our cars are going to go through.
Not saying it doesn't work, but the pistons all come from this IIIH testing, not from an on the road test.
"Real-world testing is crucial. For instance, a Ford Mustang was subjected to extensive testing with Restore and Protect, showing significant reductions in wear and deposit formation. The testing extended to various engine components, including the timing chain cover, oil pan, and valvetrain, demonstrating the comprehensive benefits of the oil. The team also ran Restore and Protect in a Ford Explorer with more than 500,000 miles."
“And we also did a chassis dynamometer test where we put a vehicle on rollers basically and ran it 300,000 miles,” Warholic says. “Restore and Protect actually cleaned up the entire engine.”
Good point, but if R&P can't remove relatively soft carbon and varnish with reasonable effectiveness, how is it going to clean extremely hard baked on carbon off the rings and out of their grooves with minimal oil exposure? Those deposits are usually so hard they have to be scraped off with the sharp edge of a broken ring or similar and still usually take several passes to fully remove AFTER soaking in a strong solvent. I've seen rings stuck so badly that they are almost impossible to remove.
Here's a picture from Valvoline's website of the type of cleaning R&P supposedly did in one of their tests. Sure looks to me like they are indirectly claiming varnish removal.
It's hard to say which oils do or don't reduce piston deposits since they aren't easy to inspect. Oil consumption can be an indication, but there's still too many other variables to say for sure, especially on a car with unknown history.
Yes, a longer term test would be ideal, but as I said, I'm going to pull the engine for a manual cleaning and refresh shortly, so there wasn't time for long term testing on that.
I personally don't consider that tiny bit of cleaning in 2500 highway miles proof that R&P has some special cleaning ability, especially without knowing the car's history. I've seen other oils do more cleaning over the same mileage in other engines, but that's obviously an apples to oranges comparison.
My friend's CRV is on its 4th OCI on R&P with no change in oil consumption yet. Could that change? Possibly, we'll see what HPL EC30 does. And without tearing down the engine, we don't know for certain that the oil consumption is due to stuck rings, that's just an educated guess since that's by far the most common reason the K series burn oil, especially that era with the warranty extension due to sticking rings.
Independent testing would be nice to see, especially since Valvoline provided no details that I could find on how the test was performed, over what duration, in what engine, etc. Even if the pictures weren't fabricated, that doesn't mean they are at all representative of real world conditions. For all we know, they could have (and likely did) create an unrealistic test just to get impressive looking results.
A control would have really strengthened their marketing too IMO. It would have been nice to see one or more common synthetic oils from other brands put through the same cleanup test on the same deposits formed the same way for the same duration and under the same conditions as a visual comparison of how their oil cleans better than others.
And yet all the pistons are from the modified IIIH test. I've not seen one part from the dynamometer testing, etc.
There could be other modifications, but I mostly take the "modified" to mean, they're taking pistons that come out of the regular IIIH test with a baseline oil and try to clean em by running R&P. That's a modification. The original test is taking clean pistons and running IIIH.
I don't know either. I'm running the product right now for the second time. I just don't think real world is going to be as dramatic or as fast as that intense IIIH test.
Great point, that's yet another potential variable on my friend's CRV. Might be worth doing a compression test and leakdown test to get somewhat of an idea of whether that might have happened. At idle, the blow by seems normal for a K24 and the engine runs pretty well, but a compression test would be interesting.If rings get stuck for long enough, they could be worn to such a degree they won't ever provide an adequate seal again. Out of round so to say. And in turn this could have worn the bores aswell.
One other thing to consider: Is the oil consumption diagnosis correct? You are assuming the consumption is due to stuck oil rings. Perhaps it is from ring or cylinder wear. Or valve seal wear or any number of other factors?Great point, that's yet another potential variable on my friend's CRV. Might be worth doing a compression test and leakdown test to get somewhat of an idea of whether that might have happened. At idle, the blow by seems normal for a K24 and the engine runs pretty well, but a compression test would be interesting.
But even if the rings and/or bores were worn from stuck rings, if the rings were then totally cleaned and freed up, would it not be reasonable to expect even a slight decrease in consumption? Since the start of the testing, his consumption has remained steady at 1 quart per 1K miles.
I guess the fact that the consumption hasn't gotten any worse over the last ~16K miles on R&P could in a way be considered maybe a slight win.
As I said several times, I have no way to know for sure since he's not interested in tearing the engine down at this time. Stuck rings are almost always what causes excessive oil consumption on the K series and it's a common enough issue that Honda issued a warranty extension, but of course that's by no means a verified diagnosis, just an educated guess.One other thing to consider: Is the oil consumption diagnosis correct? You are assuming the consumption is due to stuck oil rings. Perhaps it is from ring or cylinder wear. Or valve seal wear or any number of other factors?
Perhaps, as we have seen it in some valve train photos there is a tipping point when the deposits are no longer dissolvable by the oil. The carbonization process is too far gone and the solvents in the oil are unable to attack the polymers created.But even if the rings and/or bores were worn from stuck rings, if the rings were then totally cleaned and freed up, would it not be reasonable to expect even a slight decrease in consumption? Since the start of the testing, his consumption has remained steady at 1 quart per 1K miles.
