2-cycle oil as a fuel add in 4-cycle engine
Originally Posted By: Jax_RX8
I stated it was a better cleaner.
And you still don't have a single grain of proof to back that up.
And no, I didn't change the subject, I'm trying to bring it BACK ON TOPIC.
Except that they don't (do the same thing). FP products lubricate well, but are far superior cleaners!
I have yet to see a single grain of proof of this.
Originally Posted By: Craig in Canada
You forgot to do all the math.
FP+ treats at 1300:1. I can't say I've seen any of the supporters of 2-stroke mixing that high.
Clearly, if you are mixing FP at 1300:1 then you are NOT lubricating nearly as well as if you mixed 2 cycle oil at 500:1 or less. FP also has less oil in it to begin with, it isn't ALL oil like a gallon of 2 cycle is.
Careful there, a gallon of 2-cycle fluid is not 100% oil either.
An amount of 2-stroke "oil" will be anywhere from 60-80% oil, with the balance being a mix of solvents and other agents to lower flashpoint and ensure burn.
Since the PZ Marine Semi is up to $13, I bit on the SuperTech TCW-3 for $10. I want the best product, but not at +30% price. We all know all that stuff is blended to a spec, once it's met the product is finalized, no great gains to be had by spending more money, especially in a low dose situation. This is even moreso considering all TCW-3 is "ashless", no more or less ash to consider. Ash-less. PepBoys MAG brand is a buck less at $8.xx.
I just 17.8mpg in my 1996 Crown Victoria Police Interceptor, and I was *not* being gentle with it. Probably 95% city driving. That was after I let the computer get used to the 88 octane and 550:1 ratio of Super Tech 2 stroke oil on a recent trip. They're rated for 17 city, but I've removed the mufflers and air box restrictor to maximize air flow. I'm lucky to get 17 when I drive like a grandma. This oil is definitely helping.
None of us can prove directly that this helps. Only statistics over many tanks will show that. Although based off of experience it does help in low doses. My car likes about 1000:1, or roughly 1 oz per 10 gallons.
Glad you're seeing a direct difference.
Over the years I've used a variety of TC-W3 oils at about 400:1 in some of my vehicles that had mega miles on them.
We have run our vehicles thru many EPA inspections with no issues. However, I do skip pre-mixing a tank and run a fuel additive treatment thru before hitting the sniffer. If that makes any difference I'm unsure.
I've never seen a big fuel mileage change. However, I never tracked it that close but will be soon in my 07 Cobalt. This will be a good car to try and see if anything can be done in regards to mileage as it gets run over the same course very day. The mileage the wife gets is very consistent as well. After a couple months of playing, while not telling her what I'm doing, we'll see if there's a seen difference on the DIC.
Also, in some cases the fuel pumps are quieter when using the mix.
Have been doing my little experiment on the Cobalt, which the wife drives every day. Started with a 400:1 premix.
My first impressions were, very little change was felt or heard. It seemed to idle a bit quieter but nothing else. This engine has been a sweetheart from day one so my expectations were low per any improvement on sound or drivability, which have seemed slight.
The wife did ask what I did to the car. She knew I was tinkering thus she asked. I asked why and her reply was it idles quieter and seems smoother at low speeds. ???????????
Mileage has improved. After 2 tanks the DIC has went up .6 MPG or about 2%. Now the next 2 tanks won't be treated. We'll see if the mileage drops.
Meanwhile she's still in the dark as to what, if anything I've done to hopefully not change her driving habits.
After 2 tanks with the premix, 2 without and now 2 tanks with the mix again I have some preliminary results.
On average using a 400:1 mix the mileage results per the DIC were 2% better.
Now I'll play a bit with the mixture. Will vary from 400:1 to 600:1. This will take several months to conclude.
Just a fast update on the 07 Cobalt 2.2 W/Auto.
All of my recent experiments with running a TCW-3 mix at 400:1 and down to 700:1 have all shown a mileage increase of 1 - 2% over using no mix. Lower effects were seen with the 600:1 & 700:1 mixtures.
Did try one tank at 200:1 and no further increase was seen.
While only one tank was run "rich" @ 200:1 the initial findings suggest 400:1 or slightly less maybe 500:1 is the optimum amount.
It could be said 2% is hard to prove. However, this has now been documented on the same car with the same driver while the driver has been unaware of what I've been doing over 12 fillups and being fueled at the same pump.
2% will not in the big picture be a major cost savings issue at the pump. Even if no fuel savings were seen the other possible benefits should outweigh any minor costs with the mixture.
This experiment is now being done on a 06.5 Kia Optima I4 with 5 speed auto that sees mostly Interstate driving. The car has 20K miles and good base line has been set. See ya' in a couple months after a good road trip.
I think 400:1 to 500:1 seems to be the sweet spot for me as well. OD'ing cut power and economy. I would lean toward the 400:1 dose for the possibility of protection of the cyl walls and other combustion chamber areas, when my vehicle sits for a week or more in the garage. I think there are a lot of benefits that the general public is not aware of, only us BITOG'ers that are willing to experiment.
Frank D
2% more than covers the cost of using it. $.20c to treat 10g. 2% of that added equals about $.60c of mileage, a >2:1 payoff?
Hey Audi Junkie...
What magic juice are you using my man? $.20 is a good price I need to get down with that formula...saber outboard (got lots of it) is a bit more than that.
On another forum, specifically related to a vehicle with a Toyota 4.7 V8, I asked what they thought about 2-stroke oil in gasoline. I was met with plenty of criticism, mostly saying that it can't do any good and can only damage my engine/fuel system. I took all their opinions with a grain of salt, and simply continued to do what I like.
Then the most recent post caught my attention:
-Quote:
"Adding 2 stroke oil (or any oil) to gasoline can significantly lower the octane rating. It can even cause pre-ignition and engine destruction, especially at high speeds/loads.
Top Tier gasolines contain all the detergents and upper cylinder lubricants you need.
FWIW, I used to teach technicians how to measure fuel quality and operate and maintain octane rating engines. And I worked in developing gasoline additive formulations."
-End Quote-
To me, this doesn't sound right, especially the comment about how it "significantly lowers octane."
What do you guys think?
Originally Posted By: Eddie
This thread is dead IMO-kill it moderator
That wasn't very nice. I feel I had a legitimate question. I've read through pretty much this whole thread and I don't think the effect on octane has been addressed.
If anyone cares to answer, mine is 2 posts before this one.
Overdosing will kill Octane, and if it doesn't it certainly cuts down power. The proper mix will give the benefits that others and myself have mentioned. I have said before, I believe that the proper dose, and it varies with different cars etc. will raise compression, which will increase power and MPG. Too much will not burn properly and will cut power and can foul plugs... A 400:1 or 500:1 mix should be fine.
JMO,
Frank D
That's funny you mention the concentration, because in the other forum's thread, I specifically explained how I added about 4.5 oz to a 24 gallon tank. I also pointed out several times that this is a minuscule concentration of 680:1. Even then, several people criticized me for causing damage to the fuel system, engine, and say there are no possible benefits. A couple of them even claimed to read on here (i.e. on bitog) plenty, one claiming for 7 years. And then they say that on bitog, there is very little support for using 2 cycle oil.
I started the thread in the other forum because I noticed what appeared to be a remarkable increase in MPG, though I didn't draw any conclusions just yet. I told them the concentration, the apparent results, and asked what they thought.
I've noticed that 2 stroke oil in my fuel does indeed lead to more detonation when driven hard. That's why I'm running higher octane fuel now.
My car has always had detonation problems, though. My pistons look like they're made out of blocks of carbon. Seafoam, Regane, B12, nothing has touched it.
The marine TCW3 is formulated to attenuate octane reduction [compared to air cooled 2 stroke oil].
But at the levels used for us, like 3-600 to 1, it really is a non issue.
With that kind of carbon build up, you're going to have detonation. I would consider trying water to remove the carbon, its been discussed on this board many times, and has been a very effective way, give it a try. Just be sure not to lock up that engine by drowning it with too much water.
HTH,
Frank D
I've done water several times. I've done alcohol, carb cleaner, and the other things listed.
I don't think there are many top tier gasoline's available here, and the police fed the car whatever they could get cheap.
I'd like to put a water injection setup on it, but any time I come up with enough money to do so something else will catch my interest.
I hear you. I remember many years ago, early 80's I think I bought a water injector. It sat in the box I lost interest and never used it. If you've done all those things w/o luck you have 2 choices: A. tear the engine down and clean it, B. live with it......My choice B............
Or give water another shot, this is BITOG we don't usually give up! :)
Frank D
I rigged up a jug and a tube to connect below my throttle body. The tube is incapable of flowing enough to lock the engine up, so I should be good.
I'll warm the engine up and run about half a gallon of water through it this morning. If it goes smoothly, I might even do a full gallon.
I'll wait until tomorrow morning to pull a plug and check for improvement.
