Over the years I've used a variety of TC-W3 oils at about 400:1 in some of my vehicles that had mega miles on them.
We have run our vehicles thru many EPA inspections with no issues. However, I do skip pre-mixing a tank and run a fuel additive treatment thru before hitting the sniffer. If that makes any difference I'm unsure.
I've never seen a big fuel mileage change. However, I never tracked it that close but will be soon in my 07 Cobalt. This will be a good car to try and see if anything can be done in regards to mileage as it gets run over the same course very day. The mileage the wife gets is very consistent as well. After a couple months of playing, while not telling her what I'm doing, we'll see if there's a seen difference on the DIC.
Also, in some cases the fuel pumps are quieter when using the mix.
Have been doing my little experiment on the Cobalt, which the wife drives every day. Started with a 400:1 premix.
My first impressions were, very little change was felt or heard. It seemed to idle a bit quieter but nothing else. This engine has been a sweatheart from day one so my expectations were low per any improvement on sound or drivability, which have seemed slight.
The wife did ask what I did to the car. She knew I was tinkering thus she asked. I asked why and her reply was it idles quieter and seems smoother at low speeds. ???????????
Mileage has improved. After 2 tanks the DIC has went up .6 MPG or about 2%. Now the next 2 tanks won't be treated. We'll see if the mileage drops.
Meanwhile she's still in the dark as to what, if anything I've done to hopefully not change her driving habits.
After 2 tanks with the premix, 2 without and now 2 tanks with the mix again I have some preliminary results.
On average using a 400:1 mix the mileage results per the DIC were 2% better.
Now I'll play a bit with the mixture. Will vary from 400:1 to 600:1. This will take several months to conclude.
