2-cycle oil as a fuel add in 4-cycle engine
Originally Posted By: chevrofreak
I think my car was smoother on the 2 stroke as well, but I'm getting better mileage using the Lucas. I'm seeing just a tick over 19mpg in the city. Though, I haven't used the 2 stroke oil since I did that combustion chamber cleaning. Maybe I should switch back for several tanks to compare.
Which ratio do you use ?
For the UCL I seem to get the best results at 640:1 or so, and I was running the 2 stroke at 500:1 for a while, but it seems to do great at around 640:1 as well (1 ounce per 5 gallons).
If I do 3 ounces per 10 gallons with UCL my car runs a bit funny.
I use homeopathic doses
They are enough for lubricate the fuel system.
I tried Lucas at 1:700 the car was loosing power.
640:1 is what I'm running too in my vehicles. My corvette didn't seem to like it though (probably a compression/octane issue) so I discontinued maybe I should try a homeopathic dose too LOL.
Over the years I've used a variety of TC-W3 oils at about 400:1 in some of my vehicles that had mega miles on them.
We have run our vehicles thru many EPA inspections with no issues. However, I do skip pre-mixing a tank and run a fuel additive treatment thru before hitting the sniffer. If that makes any difference I'm unsure.
I've never seen a big fuel mileage change. However, I never tracked it that close but will be soon in my 07 Cobalt. This will be a good car to try and see if anything can be done in regards to mileage as it gets run over the same course very day. The mileage the wife gets is very consistent as well. After a couple months of playing, while not telling her what I'm doing, we'll see if there's a seen difference on the DIC.
Also, in some cases the fuel pumps are quieter when using the mix.
Have been doing my little experiment on the Cobalt, which the wife drives every day. Started with a 400:1 premix.
My first impressions were, very little change was felt or heard. It seemed to idle a bit quieter but nothing else. This engine has been a sweetheart from day one so my expectations were low per any improvement on sound or drivability, which have seemed slight.
The wife did ask what I did to the car. She knew I was tinkering thus she asked. I asked why and her reply was it idles quieter and seems smoother at low speeds. ???????????
Mileage has improved. After 2 tanks the DIC has went up .6 MPG or about 2%. Now the next 2 tanks won't be treated. We'll see if the mileage drops.
Meanwhile she's still in the dark as to what, if anything I've done to hopefully not change her driving habits.
After 2 tanks with the premix, 2 without and now 2 tanks with the mix again I have some preliminary results.
On average using a 400:1 mix the mileage results per the DIC were 2% better.
Now I'll play a bit with the mixture. Will vary from 400:1 to 600:1. This will take several months to conclude.
Just a fast update on the 07 Cobalt 2.2 W/Auto.
All of my recent experiments with running a TCW-3 mix at 400:1 and down to 700:1 have all shown a mileage increase of 1 - 2% over using no mix. Lower effects were seen with the 600:1 & 700:1 mixtures.
Did try one tank at 200:1 and no further increase was seen.
While only one tank was run "rich" @ 200:1 the initial findings suggest 400:1 or slightly less maybe 500:1 is the optimum amount.
It could be said 2% is hard to prove. However, this has now been documented on the same car with the same driver while the driver has been unaware of what I've been doing over 12 fillups and being fueled at the same pump.
2% will not in the big picture be a major cost savings issue at the pump. Even if no fuel savings were seen the other possible benefits should outweigh any minor costs with the mixture.
This experiment is now being done on a 06.5 Kia Optima I4 with 5 speed auto that sees mostly Interstate driving. The car has 20K miles and good base line has been set. See ya' in a couple months after a good road trip.
Just finished a 3,000 mile trip with the Kia. Overall I ran a 576:1 ratio. 640:1 seems to be the falling off point per any mileage gains.
Overall mileage had little change from the last trip both on my scan gauge and manual recordings. Weather and driving conditions were similar. However, the last trip had little or no ethanol involved where as on this trip all pumps were posted "up to 10%" ethanol.
10% ethanol should drop mileage about 3-4%. The 2% or so gain with the mixture would account for the little "overall" change from the last trip.
More as this experiment continues.
Is anyone using the Supertech Marine 2 stroke oil that comes in the white bottle? It doesn't have WPP molded into the bottom like the blue bottles do, these say CKS. It's a little more expensive, $2.17 for 16oz vs something like $1.97 for the blue bottle. It smells a bit different as well.
Oops, I managed to overdose my car
The measuring stripe on the side of that bottle is useless. The oil was so viscous that I couldn't read it after I poured and managed to pour 6 ounces in instead of 3, so now I have about 250:1 in there and it puffs smoke occasionally
I've overdosed mine a few times, never noticed any smoke. I did notice a drop in power and mpg though.
Frank D
I buy my SuperTech in the gallon? bottle. I use a 95 cent plastic graduated beaker to measure a 500:1 mix. I pour from the beaker to a small pill bottle and take it with me to use when filling with gas.
I pretty much do the same thing. I go the Gas/oil mixture ratio calculator, punch in a 400:1 mix. If gas is $2.70/gallon and I am putting in $30 I base my calculations on that, then measure it off and pour it in an old bottle of FI cleaner, or something similar. I get to the gas station pour it in and gas up. Works just fine for me.
Frank D
I usually do that too, but I figured that the level stripe down the side would work well enough for the few uses that a 16oz bottle would give me. I was wrong
My car is running surprisingly well for being at about 250:1
I think my car likes that other formula better than the WPP produced TC-W3 that has the incredibly strong odor.
Just put some in my gas tank for the first time. Seems maybe very slightly smoother. 500:1 ratio. No smoke. Runs good. Definitely did not get a loss of power. This is with Shell 87. Its the cheapest around here right now anyway! Woohoo!
I have an amsoil saber outboard bottle that I use. Not as exact as a graduated cylinder, but only one transfer (no loss to the walls), and it is measured in ounces. 2 ounces for a 12-15 gallon fillup is good for me.
I also use a rotation of fuel adds, since each has the potential of doing something a little differently, or leaving its own residue.
http://msds.walmartstores.com/cache/24970_1.pdf
That's the MSDS for it. I just compared the smell of the two Super Tech Marine TC-W3 oils and the blue bottle has a very strong smell to it that's like a combination of gasoline and diesel. This stuff has more of a mineral spirits smell.
yeah, blue bottle is disgusting. It stinks, and any slight residue is very noticable in the car.
It smells like partially combusted hydrocarbons, not like virgin gasoline or diesel. Its really odd and I really dont like it. I wont be buying supertech again, unless I leave it in the garage to put into the diesel.
