Originally Posted By: bdcardinal
That one should have a drain plug on the trans and a drain and fill plug on the differential. Just do both with whatever ATF you have on hand, when I did my former roommate's I used Mobil 1 ATF.
+1
Differential is separate from the transmission on these. I changed my differential fluid a few months ago and did a drain and refill on mine.
17mm wrench for the filler hole on the differential, it's on the backside.
Roughly a 10mm Allen head for the drain plugs on transmission and differential. About 2 quarts drains out of each with a drain and refill.
I used a fluid pump from harbor freight to fill my differential, stuck the hose in by going up and over the subframe while under the car. Fill until it starts to pour out and put the bolt back in.
They take Dexron III fluid, I always use MaxLife ATF fluid in my current 2000 Camry and my previous 1997 Camry.
