I am going to do a home brew trans flush (kind where you disconnect the cooler hoses and refill as it's getting pumped out, a little at a time).
The pan gasket is leaking from the previous yahoos, so I'll have to replace that as well. I was thinking of dropping the pan before, cleaning it and the magnets off, and replacing the filter, so whatever crud gets washed off by the flush will have plenty of surface area to stick to. But then I might be dealing with a paritally saturated filter/magnets from the get-go. If I flush first, will I be overwhelming the capacity of the magnets/filter?
The car is a 2000 Camry with a V6 with 67k miles. I presume it's had one drain and fill at around 30k, and the tech overtorqued the pan bolts, causing the leak.
