- Joined
- Feb 6, 2021
- Messages
- 1,080
So today I flushed the camry's transmission fluid, the odometer was at 90,052.
At 90,052 and mostly being highway miles, the fluid did still have a redish tint to it, so it is possible to just flush it at 100,000 but I flushed early.
Flushing this transmission was very easy to do, but it sucks that you must open a wheel to get to the fill port, if there is an adapter to pump fluid into the pan, get that instead of having to open the wheel as the adapter will make it much easier to do.
You will need 3 jugs of valvoline maxlife (what I used and is 17.99 on amazon per gallon) or whatever you prefer and also a transmission filter.
-IMPORTANT to make sure the car is leveled when you are doing this for accurate final fill of transmission fluid
You will need allen key set to loosen the pan drain plug and the straw that helps with the level, a ratcheting clamp remover (which made the job waaay easier, but optional) , a good big pan able to hold around 8 quarts, and some tubing that is 1/4, and a hand pump or whatever pump you have to pump the new fluid into the pan (if you have an adapter) or the side port.
Locate the transmission cooler
<--- It looks like this , locate the lower tube on the cooler, follow that tube and it should go down, and at the end of that tube, disconnect it, and then in the metal pipe sticking out, insert your tubing, and then route the tubing into a pan or something.
Go underneath the car where the transmission pan is, remove the hex bolt, it should be on tight , so use some strength, and then some fluid might come out, if not, with the same allen key, remove the inner plastic straw, and then the old fluid should come out, with the straw out, if you have a transmission filter, remove the whole pan, remove and insert a new filter, screw in your fill adapter if you have it and then connect it to your pump and transmission fluid jug with new fluid in it, make sure you pump at least 4 quarts into the pan, no worries of overfilling as this is going to be used to flush everything out, after you have done that, start the car and make sure you turn it off if bubbles start coming out IMMEDIATLEY! , I stayed on the safe side and just let the car run for 3 seconds, pump new transmission fluid, and then repeat that until new fluid starts coming out.
Once new fluid comes out, make sure you put the return line back and put the clamp back on.
Underneath the pan, remove the adapter, put the straw back in first and then bolt.
Let the car get to operating temperature, and then open the drain bolt again to check if fluid is coming out , if alot of fluid is coming out, let it drain until it starts trickling, if no fluid comes out, you will need to fill the pan more. After you have gotten the final fill completed, put the drain plug back in. You should be done.
Don't do this in a transmission with like 400,000 miles and the fluid was never changed, at this point you might need another transmission or rebuild it.
