1. Is the filter not changeable without trans disassembly? It does not seem to have a traditional pan to remove.
2. Towards the rear of the auto transaxle, there is a plug, is this an transmission fluid drain plug? If so how much will come out?
3. If I can only flush it out by removing a cooler line and running it while pouring fluid in and not changing the filter, would you recommend addding a magnafine in line filter to the hoses when connecting them back up?
Thanks in advance!
Thanks in advance!
