Originally Posted By: armos
I just want to make sure it's clear that the temperature of the transmission fluid is not the same as the engine coolant. If, for example, the trans fluid wasn't circulating properly, you wouldn't see that on the engine coolant gauge. Most cars don't have a trans fluid temperature gauge, and I doubt any Taurus does.
But I agree, it sounds like an electrical problem, since disconnecting the battery fixes it without cooling off.
I'm still wondering about possible solenoid failure, but I'm not sure how disconnecting the battery would fix that either.
Check engine light is a good point, make sure it works and if you have any CE codes look into them. Since it's a computer controlled transmission, who knows what voodoo is at work here.
Is there a fuse for the ECM? What happens if you just pull that fuse, to reset the ECM but maintain power to everything else? I'm not sure what that would prove, but it helps isolate the symptoms to the ECM.
This seems to be a transmission electronic controls issue.. to diagnose that will take a lot of research or the help of a transmission shop. It's possible that the official service manual has troubleshooting steps for these particular symptoms, but who knows.
Maybe a bad ECM.. but I'm always skeptical of that diagnosis. It's the kind of thing people usually guess wrong about.
I really suggest you try to get ideas from a Taurus forum, they might know details about these cars that could explain why it could act like this.
I am going to do some cooling system flushing and probably get a Haynes manual, though I have to say, I have found Haynes somewhat useless in the past. Though I will look at it in the store before I determine that.
If the Voltage Regular and Rectifier are internal to the Alternator, then maybe I also need a new one of those.
Checking out the link for that product dishdude mentioned, I ask because I do not know they are out there.
It shifts non-clunky a lot more than it did now.
The Check Engine light comes on when the key is turned to "on" but engine not started so it is not setting any DTCs or trouble codes.
I also made the post on Taurus Club or TCCA forum, let's see if anyone responds. I posted in detail.
