- 4/26/03 3/9/05
1.5 Liter
110779 124481
OCI: 3120 miles 2510
Bosch Premium oil filter Supertech oil filter
KN Air filter Fram Air filter
Analysis done by ANA labs Oil guard
Valvoline Maxlife 5w30 Advance Auto
Makeup:Maxlife 10w30 1.25 quarts 300 ml
Oil use from 10/02-4/26/03 10/04-3/05
SB - 0
TI - 0
AG - 0
CU - 1 3
PB - 14 1
SN - 7 0
AL - 4 2
NI - 0 0
FE - 6 0
CR - 0 0
CD - 0
NA - 0 0
B - 11
SI - 2 15
V - 0
K - 10 0
MO - 26 49
MG - 62
CA - 2839
BA - 0
P - 889
ZN - 969
SYSTEM - ENG
WATER - 0.05 0
SOLIDS - 0 0
GLYCOL - N 0
FUEL - 0 0
SAE_GRADE - (BLANK)
TBN - 7.1 8.1
PHY_TAN - 0
VISC - 10.47 10.9
VISC_TEMP - 100
Nitration 1.3
Oxidation 2.4
First UOA on left from two years ago. This one is on the right is so unbelievable that I refuse to believe it's accurate! Check engine light on almost the entire interval. I smell gasoline in the oil. I'm getting 60 miles less per tank. TBN is 8.1 LOL dinos don't start that high especially the store brands. Lead, fuel, viscosity, TBN are inaccurate. I'm surprised silicon is only at 15. I put a new valve cover gasket, rear main seal, and oil pan gasket on this car before this oil was put in. Before the rear main seal was replaced, the engine was run so low on oil it was drastic. I was losing a quart in 8 miles and I get great wear. lol. With the Pennzoil HM confusion in the virgin oil forum. I'm going to send my mix of pennzoil HM to two labs.
