1990 toyota corolla 1.8d transaxle fluid
What is the difference between a 80w90 gl4 multigrade mechanical transmission case oil and a sae 80w90 gl5 mechanical transmission case multigrade oil? What mechanical transmission oil would you recommend for a corolla 90 diesel 1.8d 1c engine with mechanical transmission and integrated differential?
these are the oils available to me:
liquimoly gear oil with gl4 sae 85w-90 specs
shell spirax s4 ax 80w90 with gl4 specs
thanks
jorge
