1977 Corvette Oil Recommendation
An oil I didn`t see on the list,Mobil 1 High Mileage. It`s supposed to have 1100ppm of zddp. Here`s what Mobil said:
It has enough ZDDP additives for the flat tappet camms. -- Thank you for contacting ExxonMobil.If you have further questions you may contact 1-800-ASK-MOBIL. -MJ
Consider an additive to get the oil ZDDP [zinc] levels up to where they were when the car was made.
Or maybe Lubro Moly additive - I use it.
HDEO can work pretty good, like a 15-40.
12K on the car. Family member bought it last year and has yet to change the oil. It's a show car, all original minus a custom paint job and pin stripes. I know next to nothing about classic cars and oil needs other than modern oil = bad.
Modern oil is VERY good.
EXCEPT for older or high performance engines with hot cams and high spring pressure.
then an additive is smart, HDEOs are not perfect, but are in the right direction.
AFter break in of the engine, the need for zinc is reduced.
Valvoline VR1. Most zinc that you'll get from an off the shelf oil, and it's under 5 bucks a quart. No reason to look harder or spend more.
Valvoline ZR1 10w30. This oil is as close a formulation as you can get to what was available when your car was new. It's also cheap and widely available. Change it every 3k miles.
+1 Great oil for this app. Also HDEO 10w30 fits the bill. I'd stay with a 30 unless you're planning on getting the oil into above average temps. as in racing.
30 weight max-this is a low output motor turning low max rpms-and max rpms (? 5000 ?)--we are talking about 185 hp max here--probably NEVER happen. Absolutely no need for a heavy 15-40-- it was never the recommended weight in the owners manual. 5-30 or 10-30 will do fine-how about Mobil 1 High Mileage 5w30 with one half bottle of ZDDPlus additive ?
