Originally Posted By: CBR.worm
So the lincoln that ran 100,000 miles without an oil change had 1qt added every 1k, so 100 makeup quarts in 100k. Today I change my oil about every 7.5k (I know, too soon - but it's a VQ35) and have used about 111 quarts in the last 100k
Essentially he had oil changes quite regularly without the benefit of a drain.
Yeah had the oil consumption been less than 1 qt/10k miles, then that would been impressive. At 1 qt/1k miles he was replacing all the oil every 5-7k miles. Not too impressive really. Today's SM Group II oils have come a lot closer to todays Group III synthetic. Apparently Mobil 1 was mostly PAO with some ester back then. But I guess the Group III is about as good.
